astroflex code 15?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=72654
Printed Date: April 22, 2026 at 4:07 AM
Topic: astroflex code 15?
Posted By: slyone69
Subject: astroflex code 15?
Date Posted: February 11, 2006 at 9:35 PM
Can anybody help me?? I'm working on a 98 chevy tahoe with an astroflex QS5 everything was working fine until we tried to reloacte the antenna. Now there is no Start attempt, no lock/unlock, just a code 15....code 15 isn't listed in the installers manual...tech support is closed until monday...help
PJK
Posted By: KarTuneMan
Date Posted: February 13, 2006 at 9:23 PM
On any astro....if the reciever isn't plugged in correctly, none of the transmitter buttons wil recieve. Check the cable. If thats all you did was move the antenna....thats got to be your problem.
Posted By: slyone69
Date Posted: February 13, 2006 at 9:39 PM
THE ANTENNA IS MISSING ALTOGETHER...THE OLD ONE WAS NEVER PUT ON THE WINDSHIELD...SO WE MOVED THE WIRE UP THE PILLAR AND THE UNDER THE HEADLINER TO WHERE THE REAR VIEW MIRROR IS...THE OLD ANTENNA WAS DAMAGED AND WE ARE GOING TO INSTALL A NEW ONE...I TRIED TO START WITH TRANSMITTER BUTTON, BUT NEITHER START FUNCTION WORKS, NOR DO THE LOCK/UNLOCK DO ANYTHING AT ALL. IS THIS BECAUSE THE ANTENNA IS NOT PRESENT??
PJK
Date Posted: February 13, 2006 at 10:35 PM
That is correct...without the "reciever" you get nuttin.....  when you order a new one make sure you get the XR
Posted By: slyone69
Date Posted: February 14, 2006 at 8:34 PM
YUP...ORDERED THE ANTENNA TOADY...THANKS MUCH!!
PJK
