Alarm all haywire!
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7294
Printed Date: May 08, 2026 at 9:06 PM
Topic: Alarm all haywire!
Posted By: flite_1
Subject: Alarm all haywire!
Date Posted: December 28, 2002 at 6:34 PM
Hi everyone! I'll try to lay this out as easy as possible:
The situation: I'm setting up a 3 in 1 alarm (Prostart 3in1 by Autostart) alarm/keyless/rem.starter
The vehicle: '90 Ford Taurus GL  3.0L V6
The problem: After setting up all the wiring incl. siren, hood pin, shock, etc.. The moment I hook up the main harness to the 'brain' the alarm goes off for about a minute but is still armed when it stops. I've tried all the suggessted programming methods with the hood pin, program assistance button and valet, even dip switches. And I can't use the keychain cuz it needs to be programmed first. So in other words; power goes on, alarm goes on and stays on.
Could there be a mixup in the wiring- I went over it all at least 4 times, digitally probed everything but with no improvement. I even tried to hook up the main harness only but with the same results.
Could the problem be with not using the same gauge wire in the ignition wires? Should I just connect the main 12v wires straight to the battery? (There's was no noticible voltage drop in any of the wires)
Could I possibly have tapped into the wrong wire for the Tach? (Should I be testing it for 12v DC or AC?) where else can I find a tach wire equiv. in the engine- I've heard of getting one via spark plug, but how would I do that?)
Could an improperly grounded siren, or anything for that matter be cause for concern? Or is it car related? I know that the rear defroster and driver's controls for pass. windows don't work (yet all the fuses are fine). I've also heard of malfuntioning BCM's but I don't know if I even have one- and would it even affect the alarm install?
Well, I know those are a lot of questions, but to me it's still one big problem so to anyone reading this, please try and answer as much as possible.
Thank you all SO much!
Posted By: auex
Date Posted: December 28, 2002 at 7:29 PM
First off the alarm going off when power is hooked up is normal for some alarms.  Just use the valet button and shut the alarm off or put it in valet.  The tach will be here ( taken from design tech notes):Electronic Engine Control (EEC) Module Located On Passenger Firewall. DK. GREEN/ YELLOW Or TAN / YELLOW Located At Pin #4. Spark Output Timing (SPOUT) Connector Can Also Be Used For Tach Signal (2 Pin Plug With Pair Of YEL/LT. GRN Wires.  Tach will test as ac current.  As for grounds anything that is not grounded correctly will eventually fail and lead to trouble.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: flite_1
Date Posted: December 29, 2002 at 1:42 PM
Hi, I've tried all I can with the valet and even the hood pin but it still will not disarm or respond to any programming attempts.
As for the Tach, right now I have it tapped into the (-) TACH wire at the ignition coil (which I found in my repair manual). I don't know if it works cuz of problem #1. But would this work as well? Is it AC? Cuz I tested it with the engine running and in ignition run position and it tested about +12vDC. Should I try testing for AC?
Thanks!
Posted By: auex
Date Posted: December 29, 2002 at 9:40 PM
Did you look in the owners manual on how to put the alarm into valet mode?  This should be the same as to shut the alarm off with out the remote.  Usually it is put the key in the ignition to run ( 1 click before start ) and then push the valet button ( the hood pin has nothing to do with it ).  And yes tach is AC current.
Posted By: flite_1
Date Posted: December 30, 2002 at 10:48 AM
Yeah, I've read the manual quite carefully- and it's exactly as you outlined it with no results. I've tried it while the alarm initially goes off when the main harness is plugged in and also after the alarm goes off (but is still armed).
I did find a smaller gauge wire in a separate harness in the steering column that has the same colors as the larger gauge ignition wire. Could this be anything I might need to tap into with like a 2nd ignition or something?
Anyway, here's another question; I set up the 5wire alternating relays for the locks and when I press either lock/unlock from the driver's door it sounds like it isn't getting enough power and doesn't move anything. But, the locks work fine on the passenger's door. Could I have tapped into the wrong motor wires or placed them on the wrong relay? Also, the +12v supply to the relays is linked (fused) to the battery terminal.
Thanks for your ongoing support!
Posted By: flite_1
Date Posted: December 30, 2002 at 11:08 AM
One more thing, might I be able to utilize the arm and disarm wires from the alarm? I don't have factory items like RKE. But I just thought they might still be used somehow?
And another, do I need to connect the Ground Out While Running wire from the alarm? What's a good place to put it? Should I just ground it to the body?
thanks
