791xv remote start killing car
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=72944
Printed Date: April 03, 2026 at 5:18 AM
Topic: 791xv remote start killing car
Posted By: shkeel
Subject: 791xv remote start killing car
Date Posted: February 16, 2006 at 1:46 PM
I have a viper 791xv alarm and remote starter.  Just recently my car has had problems of stalling for no reason what-so-ever.  When i brought the vehicle for repairs they told me that the remote starter was causing the distributer to just stop workin for no reason.  They said they need a schematic of the remote starters hookup but i have been completely unable to find anything.  The company that installed it just said to look on the vipers website, but that was no help.  Does anyone have any idea or a schematic that might help me in my situation.  Thanks
94 Camaro Z28
Jensen 7" Indash-DVD/mp3/tv
Rockford ChromeSeries 600/2
Power Accoustic 12" Dvc700rms
Rockford Power T162C
JLaudio 6.5" 75rms
PS2 Slim hardwired
Lightning Audio 1 Farad Cap
Posted By: gus1
Date Posted: February 16, 2006 at 2:25 PM
Unplug the XCRS and the brain..... that should eliminate that from the equaton.
Gus
Posted By: kgerry
Date Posted: February 16, 2006 at 4:09 PM
not if there is an intermittent short on the tach wire... i would look under the hook for a violet wire going to the coil or an injector and disconnect it....you can unplug the connector from the RS units brain and then meter it for continuity to ground.... or just run a new wire if thats the suspect circuit......
it's about the only thing i can think of that would cause a vehicle running to drop out for no reason like you describe.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: bazzgazm
Date Posted: February 16, 2006 at 10:45 PM
The biggest problem we have here is people blaming any aftermarket part no matter what happens. I wonder if they really tried troubleshooting or saw the remote start and said... OH! There's the problem
I'm guessing that lt-1 engine has optispark!
three cheers for that reliable system
