Cadillac STS Problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=72967
Printed Date: April 02, 2026 at 4:25 PM
Topic: Cadillac STS Problem
Posted By: Memphisman
Subject: Cadillac STS Problem
Date Posted: February 16, 2006 at 7:48 PM
I'm in the process of installing a Coolstart RS330 RS in a 1999 Cadillac STS. Everything works fine except the anti-theft. RS works with the key in the ignition. First I tried using a GMDLBP (worked a couple of times then quit). Then I tried using a GMBP. It programmed up but will not let the car start. Both units will shut off the security light but the car won't start yet the ignition will stay on and act as though its running (dash display lights up SERVICE ANTI-THEFT SYSTEM), I tried reprogamming them several times with no luck. Also tried different ground points. I also have had this problem with Park Avenues. Any suggestions?
Posted By: kgerry
Date Posted: February 17, 2006 at 11:33 AM
have you tried other bypass combinations? like a 555G and 456B together?
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
