05 pontiac bonneville
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=72983
Printed Date: April 02, 2026 at 6:46 AM
Topic: 05 pontiac bonneville
Posted By: Jrami608
Subject: 05 pontiac bonneville
Date Posted: February 16, 2006 at 10:06 PM
I just wanted to know if anyone could please give me the wiring info on this car and if  you all have any tips they will help.
Thanks alot
WiredUp
Posted By: tom badger
Date Posted: February 16, 2006 at 10:38 PM
Go to:
posted_image
select make, model & year
The Badger
Posted By: mo12v
Date Posted: February 16, 2006 at 10:41 PM
Just be prepared to do a little bit of wiring & searching.
I use the OMEGA IM-01 or GM-DLBP for ByPASS,  Locks & Trunk
DEI has a ByPASS also
https://www.directechs.com/directwire/wire_body.asp?action=select&yr=5884&product=Remote Start#
OR
Constant 12 voltsREDAT THE BATTERY
Ignition 12 voltsPINKBCM IN DRIVER ACCESS PANEL
StarterYELLOWBCM IN DRIVER ACCESS PANEL
Dome LightTAN (-) DRIVERS,DARKBLUE ALL OTHERS IN EACH DOOR AT *
Trunk Pin SwitchLT BLUE (-) AT RIMBLACK CONNECTOR IN PIN B4 **
Parking LampBROWN / WHITE (-)AT SWITCH OR DIM,BROWN CONN PIN B3***
Power LockRED / BLACKDRIVERS DOOR SWITCH
Power UnlockORANGE / BLACKDRIVERS DOOR SWITCH
Negative Pulse Door Lock Circuit
* Door Modules Diode Isolat Wires Face Cathode / Striped End Toward OEM Wires ** RIM (Rear Integration module) Is Located Behind The Rear Seat Drivers Side *** DIM (Dash Integration Module) Is Located Just In Front Of The Blower Motor Near The Passenger.
Click Here For Our Databus & Immobilizer Bypass Cross Reference
Accessories
Window UpD\DARK BLUE P\DARK BLUE D\DARK BLUE P\DARK BLUE AT EACH DOOR
Window DownF/BROWN F/BROWN R/BROWN R/BROWN
Ign Key WarnLT GREEN (-)IGNITION SWITCH HARNESS
Trunk ReleaseL BLUE (-)AT RIM IN BLUE CONNECTOR PIN #B4 *
OEM HornBLACK (-)AT DIM IN GRAY CONNECTOR PIN #A6 **
HeadlightsWHITE (-)AT DIM IN BROWN CONNECTOR PIN #B3 **
OEM Alarm Arm
OEM Alarm DisarmLT GREEN (-)DRIVERS DOOR MODULE IN DRIVERS DOOR
Reversal Rest At Ground Power Window Circuit .
* RIM (Rear Integration module) Is Located Behind The Rear Seat Drivers Side ** DIM (Dash Integration Module) is located just in front of the blower motor near the passenger.
Remote Start
Tach SignalWHITEAT INSTRUMENT CLUSTER OR PCM *
Ignition #2WHITEIGNITION SWITCH HARNESS
Ignition #3BROWNIGNITION SWITCH HARNESS (HEAT/ AC)
AccessoryORANGEIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightWHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightL GREEN (+)IN DRIVER'S KICK PANEL
Rear Window DefrostWHITE (-)AT RIM CONNECTOR C1 IN PIN B1 **
Immobilizer Bypass
* PCM (Power Control Module) Located On Drivers Side Of Engine Compartment in Air Cleaner Houseing. ** RIM (Rear Integration module) Is Located Behind The Rear Seat Drivers Side
MO
Date Posted: February 16, 2006 at 10:47 PM
Sorry about the above post.
I guess I don't know how to properly post links or websites into this forum.
The Badger
