DEI 477T 2 way remote
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=73030
Printed Date: April 01, 2026 at 9:43 AM
Topic: DEI 477T 2 way remote
Posted By: dearjimmy
Subject: DEI 477T 2 way remote
Date Posted: February 17, 2006 at 5:56 PM
I have an Ungo SR5000 alarm/remote start. I want to get another 2 way remote. It's a DEI 477T remote. I found a Valet remote which has the exact same info on the back (FCC code and model #477T). Will this work for my Ungo? Thanks!
Date Posted: February 17, 2006 at 7:46 PM
The reason why I was asking is because when I try to configure the remote by using the open door, ignition on and valet button. Nothing happens. The LCD screen is lit up and it shows it's trying to ,make a signal output, but my alarm won't pick anything up. My Ungo 477T remote configures fine though. Is there something I need to do to the remote if its not had a battery in it for some time? Should it only beep when and if the car alarm reads its signal? It makes no noise so I'm thinking that there's no real output!!!  Is there a test to check remote output?
Posted By: cntrylvr79
Date Posted: February 17, 2006 at 8:04 PM
Using a dei remote with an ungo alarm will not work
------------- Cause I'm So white and nerdy...
First Class Certi-fried installer
Date Posted: February 17, 2006 at 8:22 PM
My Ungo alarm has an Ungo remote that is a DEI477T 2 way LCD. That's a DEI remote!!!!! I just read where my remote has a 434 MHz output. I just need to see if the Valet 554R (also a DEI477T remote) has the same output.
Posted By: swamprat323
Date Posted: February 17, 2006 at 8:26 PM
i dont think it will even know that ungo are made by d
DEI. i tryied it out betewwn theungo s1000 and the python 1600, they had the same info on the back 474p and 474u.
Date Posted: February 17, 2006 at 9:31 PM
I bet Ungo found it less expensive to buy the remote from DEI. Elaewhere on here someone says the Valet 554R remote has a 433 MHz output. The Hornet 554T has a 434 MHz output (my Ungo SR5000 says it has a 434 MHz also).. Would that 1 MHz make a difference? I'm still trying to find a Valet 554R manual to make sure it has a 633 MHz output. Thanks for all your help!!!
Date Posted: February 17, 2006 at 9:38 PM
I didn't typr that last part correctly. I meant a 433 MHz and not 633 MHz!
Date Posted: February 17, 2006 at 9:41 PM
why dotn you just buy the one that is ment for it and be done with it. you dont want to buy soemhtign and it wont.
Date Posted: February 17, 2006 at 9:42 PM
I still can't type! Sorry! That's what being up for 36 hours does to me!!!
Date Posted: February 17, 2006 at 9:44 PM
The ungo is tough to find and it's over $120. I bought the Valet that I said earlier has the same info on the back, but it won't program.
Date Posted: February 17, 2006 at 9:45 PM
Does anyone know where I can get a 477T for my Ungo SR5000 at a discount!?!
Date Posted: February 17, 2006 at 9:53 PM
a lot of people sell them most around $90 or so.
check your pm
Date Posted: February 17, 2006 at 10:30 PM
Got em! Thanks for your help!
