2003 chevy suburban, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=73448
Printed Date: April 05, 2026 at 11:34 PM
Topic: 2003 chevy suburban, remote start
Posted By: jmacf14
Subject: 2003 chevy suburban, remote start
Date Posted: February 24, 2006 at 11:20 PM
Hi guys, the info I have for this rig says that the (+) park light wire is brown and located in the harness in the drivers kick panel. problem is there are two brown wires there in two differant harnesses. does any one have any more info on this? or at least a good test procedure with my dmm?thanks for the help.
------------- jmacf14
Posted By: Chris Luongo
Date Posted: February 25, 2006 at 5:49 AM
I tried to help another installer find positive parking lights in one of those, and as I recall, we had a hard time and eventually gave up.
I would imagine you should be able to find the wire at the back of the radio, though.
What are you installing? Any reason you can't use the negative parking light wire? Because that's easy to find-----gray/black at the BCM below the steering column.
Posted By: mad550
Date Posted: February 25, 2006 at 6:25 AM
Two wires one is illumination off the dimmer the other should link directly to the park lights
------------- WOW Sight and Sound
Maroochydore
Nothing is impossible!
Do it right the first time or don't do it at all.
Posted By: jmacf14
Date Posted: February 25, 2006 at 11:32 AM
Hi Chris, thanks for the reply. I am using an ultra start unit, and after reading your post, I double checked the features, and I can program the alarm for neg. park lights.(it is set up for pos. from factory. Thanks for the suggestion.
Posted By: tragik
Date Posted: February 25, 2006 at 12:30 PM
You can find the parking lights, brakes, and a buch of other useful wires in the junction box to the left of the brake. The PL and brakes go to a plug that the trailer harness would plug into if equiped. I have seen installers put small female disconnects on the pins coming out of the box, but I usually just pull the box , flip it around, and tag the wires on the back side. PL is brown, brakes are light blue. Both are going to the same plug, on the top side of the box.
------------- Northstart.....or start it your damn self.
Posted By: jmacf14
Date Posted: February 25, 2006 at 4:46 PM
Hi guys, I just succesfully installed my ultrastart r/s alarm in my 2003 suburban, with a gmdlbp module. everything works great except when the alarm is triggered by opening the door, both oem and ultrastart alarms go off, and I can only shut off the ultrastart with remote. then I have to use oem remote to shut off oem alarm. I dont want to have to carry both remotes for this. how can I shut off with aftermarket remote?
Posted By: jmacf14
Date Posted: February 25, 2006 at 4:48 PM
good to know. I know exactly the box that you are talking about!
Posted By: jmacf14
Date Posted: February 25, 2006 at 4:54 PM
I just succesfully installed an ultrastart r/s unit in my 2003 suburban, with a gmdlbp. any one have any info on how to get the aftermarket unit to shut off the oem alarm when it is triggered? it only happens when the door is opened while armed. I cant get my aftermarket remote to shut off the oem alarm.any ideas? ------------- jmacf14
Posted By: jmacf14
Date Posted: February 25, 2006 at 7:20 PM
ok, now i also have one other issue. when I arm the alarm, and the domelights finally go off it sets off the alarm.any way to fix this problem?any help would be apreciated. thanks
