Car Alarm Keyless door '94 explorer
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=73467
Printed Date: April 06, 2026 at 10:30 AM
Topic: Car Alarm Keyless door '94 explorer
Posted By: explorer94
Subject: Car Alarm Keyless door '94 explorer
Date Posted: February 25, 2006 at 11:39 AM
I have a 94' Explorer that didn't come with a factory installed alarm. I have been trying to get everything to work. I am having problems getting the door to unlock. I bought a alarm on ebay. the model # is HS-100 it is a OEM 4 type alarm and that is all I know about it. It has 6 wires for the door unlock. It looks like 2 go to the motor and the other 4 are just 2 + and  2 - . I hooked the 4 up to the unlocking and locking switch and nothing works. I have been trying for a week to get this working and still nothing. I have never installed any kind of alarm before. I have everything working but the locks.
I looked and read other forums about this problem with the explorer. I read that they are reversed polarity, positive polarity, and that it needs relays. to cutting the unlock wire.
I don't know what the problem is so any help to walk me through this is greatly appreciated.
-- ---xxxx---
Posted By: mo12v
Date Posted: February 25, 2006 at 2:10 PM
If your Vehicle did NOT come with Factory Keyless, you will need to wire it as a 5 Wire Reversal
Also, If you have a 6 wire Door Lock wiring on your HS-100, it should have instructions that show something similiar:
N / C
COM - UNLOCK
N / O
N / C
COM - LOCK
N / O
If Instructions do NOT show that, then Post what you have
To wire 5 Wire Reversal:
Cut the LOCK & UNLOCK wires ( on Vehicle ) in Half.
One cut side goes to Switch
One cut side goes to Motor ( Actuator )
UNLOCK:
N / C = Switch side
COM = Motor side ( Actuator )
N / O = 12 Volt Constant +
LOCK:
N / C = Switch side
MO
Date Posted: February 25, 2006 at 3:00 PM
My installation book has 5 different diagrams for wiring the locks. I am using the diagram that they say is for fords.
I have 6 wires 1 orange 1orange and black both of them are supposed to go to a negative pole.
1 yellow and 1 yellow and black are 12v.        And there is 1 white and 1 white and black the diagram shows that it goes to the motor.
What I am trying to do is run 1+ and1- toeach side of the door unlock and lock located at the drivers side locking switch. I had the white wires ran to the motor as the inst. say to do. Nothing Happens.
Today I took a  multimeter and tested the brain of the alarm. I tested each one of the door wires and I couldn't find any kind of a hot when I pushed the lock/un-lock. I don't know why I couldn't find a hot.
Also My alarm systems brain has an output wire for a negative trigger door side swith. it says swith I don't know what it means. This wire isn't hooked up b'cuz I have no idea where it goes.
There is also a wire that is for the Acc that isn't hooked up b'cuz I again have no idea where to install it.
If anyone can leave me a # to call you at. I would rather talk than type. I am located in the U.S. not Afgan. I made an error when registering. Thanks for all your help it is really appreciated and needed thanks
-- ---xxxx---
