2004 f250 diesel remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=73655
Printed Date: May 15, 2026 at 12:33 AM
Topic: 2004 f250 diesel remote start
Posted By: shiftkx
Subject: 2004 f250 diesel remote start
Date Posted: February 28, 2006 at 9:35 AM
Hey guys
Im new to this forum. I must say  there is tons of usefull information here. I am having a issue with my remote start, i have a compustar and i need the remote start cause its so cold outside at 330 am  i need to get the truck all warmed up.
can someone please help me with the tach sensor wire and the glowplug wires so i can connect the cm3000 to it ?  any usefull info would be appriciated. thanks.
Posted By: KarTuneMan
Date Posted: February 28, 2006 at 9:47 AM
Tachometer NOT RED / lt. green  ac  any ignition coil  posted_image
Wait to start see DirectFax document 1091      posted_image
https://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1091.pdf
Posted By: Velocity Motors
Date Posted: February 28, 2006 at 10:09 AM
For the wait to start/glow plug wire, go to an authorized Compustar dealer with a programmer and they can program in the wait to start time on the CPU.
Posted By: shiftkx
Date Posted: February 28, 2006 at 10:23 AM
so will the wait to start wire be the glow plug wire on the computar brain?
Posted By: jmacf14
Date Posted: February 28, 2006 at 6:58 PM
correct me if Im wrong, but the glow plugs light as soon as the ignition wires are energized. you dont need to connect anything to them. I dont think that truck has a wait to start wire and therefore you need to use the timer function on the alarm for about 15 seconds, or install a timer if the alarm doesnt have that function(programmable).as for the tach, there should be a geen/white wire in a 5 wire harness that has no plug(all wires cut)held to another harness with white tape just behind the fusebox cluster(held in by 4 10mm bolts.hope that helps
jmacf14
Posted By: shiftkx
Date Posted: March 01, 2006 at 8:21 AM
yea i saw that wire  so that tach wire just tap that to the yellow n black  wire from the alarm?
the alarm i have is a compustar cm3000  and it has the timer in it.  thx
Posted By: au5599
Date Posted: March 01, 2006 at 7:39 PM
behind the fuse box taped up you will see a bunch of wires. In there is a GREEN / WHITE stripe wire. That is your tach wire. Hook it into your tach input of the starter. Tach learn it. I usually max out the timer on the systems I use. Check in your install manual and it should tell you what can be programmed in there for a time delay or if you really have to hook into a wire for the light.
Posted By: larkster
Date Posted: March 03, 2006 at 10:10 PM
i have had the same problem but since i hook up the tach wire to the green red wire at the alternator and set the unit to alternator sense.  time delay to crank for 20 seconds.  I havent had a problem since and have probably done 20 of those trucks.
Posted By: shiftkx
Date Posted: March 06, 2006 at 6:06 AM
ok i got it all situated. i used the tach sensor wire and i also hooked up the 528t   compustar says when you find the right tach wire if you push the tach learn button it should beep one time  mine still beeps 3 times  but the remote start works correctly now.  i had a professional  alarm installer install my alarm and he effed it up and nothing really worked and the remote start didnt work either. so i took it into my own hands and with the help for you guys i got it fixed.  thanks guys  now i dont have to wait in a 20º truck i can let it warm up n walk down to it and be happy =)  all the security features work well with the remote start as well... thank again guys!
-oliver
www.o-stunts.com
