2002 impala door locks stopped working
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=73700
Printed Date: May 14, 2026 at 1:36 PM
Topic: 2002 impala door locks stopped working
Posted By: claytonduk
Subject: 2002 impala door locks stopped working
Date Posted: February 28, 2006 at 11:55 PM
I have an '02 impala and the power door locks stopped working . both remotes and the front driver and passenger manual locks also stopped. I checked all of the fuses in the fuse boxes on both sides of the dash and the 2 boxes in the engine compartment. when I hit the unlock or lock buttons on the drivers side or passenger side I can hear a faint click behind the dash next to the fuse box on the drivers side. the trunk still works on the remotes and from inside the car.  anyone have any ideas as to the problem? thanks
Posted By: mo12v
Date Posted: March 01, 2006 at 9:28 AM
DATA fed.......Locks get message from BCM.............You might want to check your Lock & Unlock wires for voltage.  If nothing could be Relay or BCM
MO
Posted By: xtremej
Date Posted: March 01, 2006 at 5:48 PM
I had a customer have this happen 2 weeks ago. It was traced to the BCM. replaced it fixed problem. Test first It wasn't cheap!!
Posted By: xtremej
Date Posted: March 01, 2006 at 5:49 PM
oops I forgot  to say it was  a 2001 impala.
