Blackjax Problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=73731
Printed Date: May 14, 2026 at 5:04 AM
Topic: Blackjax Problem
Posted By: audio joe
Subject: Blackjax Problem
Date Posted: March 01, 2006 at 2:46 PM
I installed an IG750 with an Intellistart 4 in a Z71.
The blackjax engages but it doesn't always kill the ignition & starter circuit and it also doesn't always rearm the alarm & lock the doors.
I've rewired the alarm, swapped the brain and I called DEI tech. Anyone else have this problem or any idea's????
Joe
Posted By: ringojam
Date Posted: March 01, 2006 at 5:25 PM
I think it an istallation problem.Here is why where did you put the ign wires from the intellstart and th 750 thi is verv important  wires from the alarm are installed after the remote start wires be carefull where you install them because you will have this problem.Did you program  auto arm and auto lock  in the alarm? 750 do not have them programed in the system.Are you in the right door switch?
Jamaica home of the worlds fastest man.
