Active Rearm stuck on-With Pics-01Tiburon
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=73780
Printed Date: May 13, 2026 at 8:33 PM
Topic: Active Rearm stuck on-With Pics-01Tiburon
Posted By: tibby01
Subject: Active Rearm stuck on-With Pics-01Tiburon
Date Posted: March 02, 2006 at 11:48 AM
My alarm is about 95% done. The only problems remaining are that active rearm is stuck on, and I'm also getting a trouble warning alert from something. This alarm is a really old crimestopper cs-9228mx, and active rearm is not a programming thing. It has to do with how the system is wired. Im hoping that the trouble warning alert has to do with the active rearm staying on, and that it will fix itself when I can finally get the active rearm to turn off. I know its active rearm, and not passively arming as well. I am an alarm n00b, and I do find myself doing things like trying to arm with the trunk open. I am pretty good as far as electronics go however, its just my first alarm install. All connections were soldered and heat shrunk.
On to the pictures. One is the page from my alarm install manual that describes active rearm. I am using the auxilary relay in my alarm brain, and have it hooked up just like the diagram that is cricled. The other photo is a schematic of my car's door/dome light circuit(2001 hyundai tiburon), with little notes on where things are hooked up. I originally had the (-) from the dome light output activated relay directly on the door trigger wire(as pictured in the crimestopper diagram), but the dome light would not turn on. I moved it to where you see on the schematic and the dome lights turn on fine now. As you can see in the schematic, practically every one of my lights in my car are leds, and I know that may be affecting things in some way. If you have any questions please ask me. I know I may have left some thigns out.
Pics:
posted_image
posted_image
Posted By: tibby01
Date Posted: March 02, 2006 at 10:53 PM
bump.
Posted By: tibby01
Date Posted: March 03, 2006 at 11:02 PM
ttt.
Posted By: tibby01
Date Posted: March 04, 2006 at 6:51 PM
guess not huh?
i think im just going to live with it. as much as i dont want to have something on that i dont desire, i want to get my car back together much more.
