Open Door Dash Light
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=73823
Printed Date: May 13, 2026 at 4:18 AM
Topic: Open Door Dash Light
Posted By: hewi01
Subject: Open Door Dash Light
Date Posted: March 02, 2006 at 11:10 PM
hey all, I own a 1998 Mitsubishi Express. I want to be able to open the rear boot door without having the dash light come on. I understand that the doors work on an open closed circuit, and there might be an easy way to wire it so when the door is opened it dosent trigger the dash "open door" light to come on. any advice would be much appreciated
Posted By: tibby01
Date Posted: March 02, 2006 at 11:32 PM
Does opening the hatch trigger anything else that you DO still want to operate normally, like a luggage light?
Posted By: floaterr
Date Posted: March 03, 2006 at 12:30 AM
The wiring charts says the trigger is a ground (-), considering that and maybe the 3rd brake light is also on the boot (maybe not) then maybe look for the wiring harness that goes between the boot and the body. Remove the rubber booty, then probe the wires for the one that goes to (-) when the boot is opened.
Maybe only like 3 wires?
1- ground (-) (for the whole boot)
2- POS (+) to brake light
3- to open close switch/sensor
Just a guess.. Good luck..
Posted By: hewi01
Date Posted: March 03, 2006 at 7:10 PM
cheers for your feedback floaterr, ill give that a go
Posted By: hewi01
Date Posted: March 03, 2006 at 7:13 PM
tibby01 - no, the luggage light I rarely use, most of the time I keep it switched to the off position and if i need it I will turn it on manually
Posted By: hewi01
Date Posted: March 03, 2006 at 7:15 PM
floaterr - you wouldnt happen to have a copy of the wiring charts by any chance would you? I have been looking for them for this particular vehicle for quite some time without any luck.
