Dei valet keyless entry and remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=73863
Printed Date: May 13, 2026 at 5:21 AM
Topic: Dei valet keyless entry and remote start
Posted By: jesterart
Subject: Dei valet keyless entry and remote start
Date Posted: March 03, 2006 at 7:14 PM
On the door locks does anyone know what type locks are on a 2005 ford Sport Trac. Do I need 2 or 4 relays for this car or maybe even none.
Posted By: KarTuneMan
Date Posted: March 03, 2006 at 7:20 PM
Power Lock pink / YELLOW  -  driver kick, door harness
Power Unlock pink/lt. green  -  driver kick, door harness
https://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1093.pdf
2 relays...
Date Posted: March 03, 2006 at 7:49 PM
Thanks for the response.  Do I need  555f for the anti-theft ?
Posted By: stroked383z28
Date Posted: March 04, 2006 at 1:07 AM
Since the door locks are straight negative trigger you don't need any relays for lock/unlock.  Just connect the green - lock wire to the lock wire in the car and the blue - unlock wire to the unlock wire in the car.  You will however need one relay since the car has three accessory wires.  Connect the pink/black to the accessory output of the DEI unit, the brown to the pink/white second ignition output of the DEI unit and program it as an accessory, and the gray / YELLOW you will use a relay to power up.  You can use a 556S or a 556U for the securilock.
Date Posted: March 04, 2006 at 1:10 AM
Also, if you are going to use positive parking lights then I would run a dedicated power wire from the battery since the red wire in this vehicle is only rated at 25 amps.
