Remote Start Harness, Clifford Matix RS3
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=73895
Printed Date: May 13, 2026 at 5:13 PM
Topic: Remote Start Harness, Clifford Matix RS3
Posted By: gordinho80
Subject: Remote Start Harness, Clifford Matix RS3
Date Posted: March 04, 2006 at 8:37 AM
I had a Clifford Matrix RS3 installed in my last car, before i traded it in for my 2004 Chevy TrailBlazer, I had it removed. I want to hook this up in the TrailBlazer now.
I purchased the GM-9 T Harness and the 457GW Bypass, i'm pretty much ready to go now...only problem is, when the system was taken it, they did a hack job.
I have seen the newer remote start systems that have the Remote Start relays pre-built and ready to go(all you have to do is plug pin into alarm box and wire the constant, ign, acc, and the starter wires), however, the previous install had the relays built...
the 5-pin ribbon runs into 4 relays and is wired as such...hopefully its easy to follow...
i just need to know how the thicker wires(2 red fused, 1 pink, 1 [ink/white, 1 orange, and 1 purple) would be ran, what they do...
posted_image
any help would be GREATLY appreciated...
thanks...
Mario
Posted By: kgerry
Date Posted: March 04, 2006 at 8:59 AM
Red (both) go to 12V Battery
Pink = IGN
Pink/White = IGN2
Orange = Acc
Purple = Starter
these go to the primary wires at the ign switch
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
