clifnet wizard
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=74079
Printed Date: May 04, 2026 at 11:42 PM
Topic: clifnet wizard
Posted By: zetecturbo
Subject: clifnet wizard
Date Posted: March 07, 2006 at 12:31 PM
right lads new here hope u can help me.
I recently had a concept 650 clifford alarm fitted to my 97 sti .and i have the clifnet wizard software installed on my laptop and have the lead aswell.
My problem is that the lead i received from my clifford dealer is for a serial connection on a computer,so i went out and purchased a serial to usb adapter.but when i connect the lead to my laptop and then to the alarm and open up the software it says comm 1 comm2 not found,comm3 wrong name and comm4 not found.anyone know how to change this.as the serial to usb adapter is setup as comm 7,8 or 9 ports.also my laptop is a hp zd8000 only has usb ports
Date Posted: March 07, 2006 at 12:35 PM
also forgot to say its the 2.2 version for xp and runs fine in offline mode
Posted By: vlepouce
Date Posted: March 07, 2006 at 2:03 PM
Go into device manager and then go to the ports area. If you go into the device for your usb to serial port bridge, look for an advanced settings. In there you can usually change the port number to something that you can use.
Date Posted: March 07, 2006 at 2:32 PM
tried that but cudnt find portsin the device manager.but tried it wen i had the device plugged in ,and found it and changed it.works fine now ,cheers for the help :vlepouce:
Posted By: Powermyster
Date Posted: March 08, 2006 at 12:03 PM
got to sort out your com ports i had the same issue just jiggles around the comms. no prolems since.. except now and again i get errors connecting to the alarm saying ecu type unknown.
Why oh Why didn't i take the blue pill
Darren Power
