Relay for 94 Tercel lights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=74090
Printed Date: May 04, 2026 at 4:01 PM
Topic: Relay for 94 Tercel lights
Posted By: cgkmark
Subject: Relay for 94 Tercel lights
Date Posted: March 07, 2006 at 3:28 PM
Does anyone know where I could find the relay for my marker lamps in my 94 Tercel because I want to attach my alarm system to it. Thanks for the help. Mark
Posted By: Twelvoltz
Date Posted: March 07, 2006 at 6:50 PM
Parking lights on the '94 Tercel are listed as
Parking Lights+ green drivers kick panel
Parking Lights- GREEN/ red column, theft ECU ( The theft ECU is located behind the radio and ashtray.)
Hope this is what you were looking for.
Posted By: cgkmark
Date Posted: March 07, 2006 at 8:23 PM
thanks that will definately help but i dont remember seeing a theft relay behind the ashtray when i installed my stereo
Posted By: cgkmark
Date Posted: March 08, 2006 at 3:53 PM
I am trying to hook my alarm up to my 94 tercels corner lights because it didnt come with that option but i cannot find the relay and when i do find the relay...how do i no what pin to attach to...i checked the headlight relay and none of the pins worked and the manual on this site says to connect to the 86 pin...can anyone help me?
Posted By: mad550
Date Posted: March 08, 2006 at 4:47 PM
Under the steering colum you'll find the wiring for the indicators and if your using a single wire split into 2 and use 2 diodes.
------------- WOW Sight and Sound
Maroochydore
Nothing is impossible!
Do it right the first time or don't do it at all.
Posted By: cgkmark
Date Posted: March 08, 2006 at 8:16 PM
I still cannot figure out this relay for my 94 tercel...in the following diagram...what is the circle with the X and L that is attached to the light? I have tried tieing into the green wire and the GREEN/ red wire and nothing is happening but i found a relay that came with the alarm system that looks like the one in the picture but its supposed to be used for the starter interupt...here is that picture
Posted By: brcidd
Date Posted: March 08, 2006 at 8:25 PM
looks like a turn signal flasher to me--- cheap and available at any parts store...
------------- Brcidd - Engineer That Does Remote Starter Installs on the side.
Date Posted: March 08, 2006 at 8:37 PM
That diagram is for an alarm that does not offer a flashing light output. It uses a flasher off relay that is triggered by the siren output from the alarm to flash the parking lights. What brand/model alarm do you have?
Posted By: cgkmark
Date Posted: March 08, 2006 at 9:25 PM
its a bulldog 2001i...its really cheap but i should still be able to hook it up...so what all would i have to do to get it to work properly?
Date Posted: March 09, 2006 at 6:41 AM
I just looked at their site and read the install manual. This is a talking all-in-one unit? If this is the unit that is listed on Bulldogsecurity.com as a 2001, the manual does not show a parking light output.
This system being self contained also does not "trigger" a siren in the same manner as a system that would be installed in the vehicle with an output to the siren. In other words, if it is the system I think it is, then you will not be able to hook your parking lights to this system without disassembling the unit, and trying to trace out the wires that provide power to the internal siren, soldering to this trace, and then following the flasher diagram. I would say, that if you want flashing lights, maybe just replace the unit with another type.
Posted By: cgkmark
Date Posted: March 22, 2006 at 12:40 PM
back to a question on this...i have the starter kill feature on the car that i have yet to install and it comes with that 87a relay...theoretically would that work for the lights?
