Backup lights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=74130
Printed Date: May 04, 2026 at 1:44 AM
Topic: Backup lights
Posted By: dlek
Subject: Backup lights
Date Posted: March 08, 2006 at 9:17 AM
I am interested in wireing my headlamps and my backup lights to the same aux channel of my keyless entry system. If anybody knows where the backup lights wiring is located, I would appreciate any assistance. Also, is the best way to do this with two seperate relays? Thanks!
Posted By: dlek
Date Posted: March 08, 2006 at 10:08 AM
car model is 1996 Cevy Lumina
Posted By: myblugt
Date Posted: March 08, 2006 at 12:05 PM
Not a pro, but heres what I'd do.
2 seperate relays.
I would look in the trunk and note the color of the bu lamp wire then look for it in the door sills, if I cant find it I'd just run a new wire to the trunk.
If the bu lamp fuse is by itself (doesn't supply anything else) you could tap into it there.
Posted By: TooDark
Date Posted: March 08, 2006 at 2:10 PM
should be light green at ing switch
Posted By: TooDark
Date Posted: March 08, 2006 at 2:12 PM
Select a New Car
User ID: Too Dark
Account Expires: 12/31/2006 12:00:00 AM
Logout
Year: 1996 Make: CHEVROLET Model: LUMINA Type: 4DR SEDAN
Remote Starters Click Here to Print
Wire Color Polarity Location
OEM Anti-Theft: PASSKEY
Anti-Theft Type: RESISTOR BASED SYS
Security Bypass Module:
Battery: RED (+) IGNITION SWITCH HARNESS
Ignition 1: PINK (+) IGNITION SWITCH HARNESS
Ignition 2: BROWN (+) IGNITION SWITCH HARNESS
Ignition 3: +
Accessory 1: ORANGE (+) IGNITION SWITCH HARNESS
Accessory 2:
Starter 1: YELLOW (+) IGNITION SWITCH HARNESS
Starter 2:
Wait to Start:
Key Sense: LIGHT GREEN (-) IGNITION SWITCH HARNESS
Brake Lights: WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Parking Lights: BROWN (+) AT VEHICLE LIGHT SWITCH
Reverse Lights: LIGHT GREEN (+) IGNITION SWITCH HARNESS
Headlights: YELLOW (+) AT VEHICLE LIGHT SWITCH
Tach: WHITE (-) AT IGNITION COIL
Fuel Injector:
Diesel Tach:
Glow Plug:
Speed Sense: DARK GREEN (AC IN HARNESS ON PASSENGER SIDE OF ENGINE C
Pwr Door Lock: LIGHT BLUE (+) IN HARNESS IN DRIVERS KICKPANEL
Pwr Door Unlock: WHITE (+) IN HARNESS IN DRIVERS KICKPANEL
Trunk Release: BLACK/ WHITE (+) AT TRUNK RELEASE SWITCH
Factory Disarm:
Factory Arm:
Horn: BLK (-) AT STEERING COLUMN
Motor Door Lock:
Motor Door Unlock:
Passenger Unlock:
Window Roll-Up: LF:DK.BLU RF:LT.BLU LR:DK.GRN RR:LT.GRN
Window Roll-Down: LF:BRN RF:TAN LR:VIO RR:VIO
Sun Roof:
Door Trigger: WHITE (-) DRIVERS DOOR SWITCH
Trunk Trigger: RED / BLACK (-) AT LIGHT IN TRUNK
Parking Brake:
Clutch Bypass:
Seat Memory 1:
Seat Memory 2:
Wiper:
Control Module:
Neutral Safety:
© copyright 2005 MobileToys, Inc. V2.2.2
