07 tahoe remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=74180
Printed Date: May 04, 2026 at 1:39 AM
Topic: 07 tahoe remote start
Posted By: qdaddy
Subject: 07 tahoe remote start
Date Posted: March 09, 2006 at 12:56 AM
i have found all wires except locks for front doors and starter wire i thought was white 1300ohm positive but does not work
Posted By: 05gt
Date Posted: March 09, 2006 at 1:07 AM
does your vehicle have a lock and unlock switch in the rear panel of the truck, like in the trunk
if it does you can use white for lock, and lt.blue for unlock both are negative trigger
if not you have to get a bypass that does databus to control doorlocks in this vehicle, I like the GM-SL
and for the starter wire it is white and did you use a 1300ohm resistor, it should work
Posted By: qdaddy
Date Posted: March 09, 2006 at 1:19 AM
yes 1300 ohm but had key in ignition and pulsed the wire and it did not attempt to start so suspected it was wrong the white wire reads 4 - 5 volts and dips when cranked so appears to be negative
Posted By: 05gt
Date Posted: March 09, 2006 at 1:22 AM
true, what gauge wire is the white wire you have hooked up to, cause I am going to say it is a thicker gauge
what bypass are you running and  what does it do when you try and remote start it
Posted By: qdaddy
Date Posted: March 09, 2006 at 1:50 AM
556u bypass and thin white maybe 16g does not start because i think it its negative but wont try again till tomorrow
Posted By: JWorm
Date Posted: March 09, 2006 at 9:01 AM
This has been covered on DEI's forum...
05gt, the 07 Tahoe is completely different than previous years,
The doorlocks are on a new GM LAN Bus. You would have to 5-wire them in each door. I would wait for an interface. The ignition is like a Colorado, or ION.
Posted By: 05gt
Date Posted: March 09, 2006 at 1:44 PM
yah I sort of gathered that but i was just was giving him ideas to check, i personally haven't done a 07 tahoe but i have done a new colorado
Posted By: NowYaKnow
Date Posted: March 09, 2006 at 6:21 PM
I tried the 5 wire in each door on the new lucerne.. No luck since the lock motors don't rest at ground.. You would need 4 relays per door.. I'll wait for a bypass. I would think the tahoe is similar.
Mike
Posted By: qdaddy
Date Posted: March 14, 2006 at 1:15 AM
anyone yet on locks or starter wire
Posted By: Twelvoltz
Date Posted: March 14, 2006 at 7:56 AM
Qdaddy...
I think most are in agreement on this one...Wait for a bypass module to be released.
Posted By: nava94
Date Posted: March 14, 2006 at 8:42 PM
qdaddy you have to wait for a bypass module, just hang tight dei should have one on the way pretty soon.
Posted By: customnate
Date Posted: March 14, 2006 at 11:00 PM
Not gonna be released till July 28th of this year!
Call DEI
Sinceryly,
The Custom Nate
Posted By: qdaddy
Date Posted: April 01, 2006 at 12:38 AM
i found the locks and to bypass use dei 555u keysense wire is pink/black use 9100 ohm resistor negative trigger and it will start this wire will start with anti-grind, accessory, ignition and no other wires are necessary use relay to separate away from switch and power relay with status remote start (-) output catch 12v at back of fuse cluster thick RED / black wires    to unlock all doors double pulse light green at switch in driver door
Posted By: extreme1
Date Posted: April 02, 2006 at 3:12 PM
XK01-GMD6
new software works with Tahoe/Impala
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: tragik
Date Posted: April 02, 2006 at 3:21 PM
When the trailblaxers came out and didnt have a module availible, I used to solder directly on to the circuit board int he dricers door switch for locks. Its not that difficult to do. Just find the points that make contact when lock and unlockl are pressed, and use a relay to connect them. If the security on that one will arm when you open the door, lock it, and then close it, all you need is to find the door trigger wire and that will rearm your security too. Disarming might be a pain tho. If its like the ion there is no disarm, so you will have to power up ignition, keysense, and pk2 with unlock.
Northstart.....or start it your damn self.
Posted By: misterjimbo
Date Posted: April 21, 2006 at 2:54 PM
i HAVE to do one of these on monday... i am not looking forward to it. i am a little confused by some of the things that were said, but we will see if it clarifies itself when i am under the dash with a .45 and a flashlight.
