keyless start and drive
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=74583
Printed Date: May 14, 2026 at 10:30 AM
Topic: keyless start and drive
Posted By: benmunger
Subject: keyless start and drive
Date Posted: March 16, 2006 at 2:03 PM
are there any alarm models that allow for keyless start and drive, much like the new lexuses and the new nissan altima?  I believe it uses blue tooth although im not %100 sure.
Posted By: xscash
Date Posted: March 16, 2006 at 6:20 PM
you could wire the car to a universal transponder interface ....and carry the transponder.  when you pass the transponder near the ring...the ign will turn on.  if this is what you want ill find the parts for you.
   XS
Posted By: KPierson
Date Posted: March 16, 2006 at 6:31 PM
You'll need a transponder system with a pretty good range on it!  xscash have you seen any with ~3 ft range?  It would be cool to install the sensor under the drivers seat or something.
Nissan uses multiple antennas though, one in each door, and one under the dash if I remember right.  I was looking though the M45 service manual, its got a TON of information on the system.  Pretty cool stuff.
Kevin Pierson
