Ground Out While Running
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7461
Printed Date: March 27, 2026 at 10:42 AM
Topic: Ground Out While Running
Posted By: flite_1
Subject: Ground Out While Running
Date Posted: December 31, 2002 at 11:41 PM
...What is it for? Do I need it hooked up (alarm w/ SK & RS) and how would I? Everything seems to work without it- but I'd still like to know.
Posted By: go2pac
Date Posted: December 31, 2002 at 11:59 PM
It could be used for manual transmission to activated the clutch relay so the vehicle can be remote started.
Karl
Pacific Accessory Corporation
Mobile Audio Interfacing Equipment
Connecting You to Your Music Since 1976
Posted By: flite_1
Date Posted: January 01, 2003 at 4:32 AM
thanks 2pac....I don't suppose it has any other uses?
Posted By: Velocity Motors
Date Posted: January 01, 2003 at 8:36 AM
This wire can be used for numerous applications:
  • controls relay for second ignition
  • controls relay for second accessory
  • used for transponder bypass turn on while remote started
  • any type of circuit that you want engaged while remote start sequence is active, this wire will turn with a relay.
