park light system for acura integra?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=74880
Printed Date: May 10, 2026 at 12:40 AM
Topic: park light system for acura integra?
Posted By: dmangru01
Subject: park light system for acura integra?
Date Posted: March 21, 2006 at 9:26 PM
I am trying to wire up the park light output from a viper alarm for a 95 Acura Integra. I tested the park light wire with a multimeter and found that when the switch was off, there was continuity to ground. Then when the switch was on , the continuity broke and I read about 50 mV. This is the first time I am coming across this type of system and don't know how to approach connecting it to the alarm output.
Could someone tell me how this parking light system works?
Posted By: Twelvoltz
Date Posted: March 21, 2006 at 9:45 PM
Here is a link to the color chart for your car. It lists it as a positive trigger, but not at the switch. If the vehicle came with a factory alarm it is also available as a negative trigger.
Posted By: pitoaudiovisual
Date Posted: March 21, 2006 at 9:52 PM
if you have the right wire and it has a ground when the lights are on and when the lights off there is no ground it will work sometimes it was a little power but not enough to trigger it, if not just use the positive parking light wire and you should be fine
------------- Confidence is the key to any project!!
I tried that RED / black wire on the green plug, but isnt it supposed to read 12 volts when the lights are on?
Date Posted: March 21, 2006 at 9:53 PM
yes
Posted By: auex
Date Posted: March 21, 2006 at 10:10 PM
What meter are you using and what does the setting on the meter look like?
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: March 26, 2006 at 9:14 AM
I am using a sears autoranging multimeter that is set on VDC.
Posted By: Velocity Motors
Date Posted: March 26, 2006 at 12:19 PM
You can get the parking light output on most Honda/Acura vehicles at the fuse box in one of the spade connectors with nothing attached to them. There will be a row of 3 or 4 spade connectors and you will find the parking lights in one of these connectors.
------------- Jeff
