05 Dodge Ram, remote start problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=74932
Printed Date: May 09, 2026 at 2:37 AM
Topic: 05 Dodge Ram, remote start problem
Posted By: gstylez
Subject: 05 Dodge Ram, remote start problem
Date Posted: March 22, 2006 at 7:49 PM
hey guys.. put a system in a 05 dodge ram 1500 today.. used the omega bypdonkey for doors and sentry key.. everything works but car will crank and start... but only stay start for under 1 min... i used one of the ignition coils for the tach... couldn't figure it out... any of u guys know where a good tach is or why its doing this..? im thinking i dont have the right tach ... any help would be great.. he's coming back tomorrow morning.. thx ahead
Posted By: xscash
Date Posted: March 22, 2006 at 8:03 PM
here is what i have.  i use a injector wire i think. and does your remote start have a self diagnose?
Battery  RED  (+)  IGNITION SWITCH HARNESS
 Ignition 1  PINK/WHITE  (+)  IGNITION SWITCH HARNESS
 Starter 1  YELLOW  (+)  IGNITION SWITCH HARNESS
 All Door Trigger  MUST USE LATCH WIRES  (-)  BE SURE TO USE DIODES TO ISOLATE
 Domelight Super  YELLOW/BLUE  (+)  DRIVERS A PILLAR
   CAN ALSO BE A YELLOW/ORANGE(+)
 LF Latch  VIOLET  (-)  IN HARNESS IN DRIVERS KICKPANEL
 RF Latch  VIOLET/WHITE  (-)  IN HARNESS IN PdonkeyENGER KICKPANEL
 LR Latch  VIOLET/ORANGE  (-)  DRIVERS KICK
 RR Latch  PURPLE / YELLOW  (-)  PdonkeyENGER KICK
 Alarm Disarm  VIOLET/BLUE  (-)  DRIVERS KICK
   1500 OHMS RESISTOR WILL DISARMS THE ALARM AND UNLOCK THE DOORS WITH A DOUBLE PULSE.
 Alarm Arm  SAME WIRE  (-)  ONE WIRE SYSTEM
   640 OHM RESISTOR, USE RELAY. THIS WILL ALSO LOCK THE DOORS.
 Parking Lights  WHITE/ GREEN  (-)  AT VEHICLE LIGHT SWITCH
   250 OHM RESISTOR WILL TURN ON PARKING LIGHTS
 Data Bus  DIAGNOSTIC PLUG UNDER DASH
 Convenience
 WIRE  COLOR  POLARITY  LOCATION
 Headlights-Lo  WHITE/ GREEN  (-)  AT VEHICLE LIGHT SWITCH
   330 OHM
 Remote Start
 Ignition 2  PINK/GREEN  (+)  IGNITION SWITCH HARNESS
 Accessory 1  BLUE  (+)  IGNITION SWITCH HARNESS
 Accessory 2  PINK / YELLOW
   THIS WIRE WILL TURN ON THE ABS LIGHT IF NOT POWERED UP FOR REMOTE START
 Anti-Theft Type  DAIMLER SENTRY KEY® VEHICLE IMMOBILIZER
 Anti-Theft Descript  THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
 Tachometer  TAN/RED  (AC)  AT IGNITION COIL
 Speed Sense  GREEN/ YELLOW  (AC)  PCM. IN A BLACK PLUG
   PIN 13. FOR SRT10 MODELS IN LOCATED IN A WHITE PLUG PIN 27. DEISEL MODELS PIN 11
 Brake Lights  WHITE/ TAN  (+)  AT SWITCH ABOVE BRAKE PEDAL
 Reverse Lights  VIOLET/BLACK  (+)  IN HARNESS IN DRIVERS KICKPANEL
 Horn  GREEN/ VIOLET  (-)  STEERING COLUMN HARNESS
 Modules
 WIRE  LOCATION
 Module 1  PCM - LOCATED ON THE FIREWALL, PdonkeyENGERS SIDE/ DIESEL MODELS IS LOCATED LOWER DRIVERS SIDE ENGINE COMPARTMENT
 Doorlocks/Windows
 Door Lock Circuit  ONE WIRE NEGATIVE SYSTEM  (-)  DRIVERS KICK
 Databus Wire  WHITE/ BLUE
 Power Unlock  VIOLET/GREEN  (-)  DRIVERS KICK
   330 OHMS FOR UNLOCK, USE RELAYS. IF THE VEHICLE HAS A FACTORY ALARM PLEASE READ THE ARM/DISARM INFO FIRST.
 PowerLock  VIOLET/GREEN  (-)  DRIVERS KICK
   860 OHMS FOR LOCK, USE RELAYS
 Driver Mtr Unlock  TAN/LT.GREEN
 Driver Mtr Lock  LT.GREEN
Posted By: gstylez
Date Posted: March 22, 2006 at 9:40 PM
where is the injector wire? and what color is it? i would like to find that one... im not sure if this remote start has self diagnose... it doesn't even have tach learning mode... so not sure..its a non name brand 2way pager remote start that customer bought.
Posted By: gstylez
Date Posted: March 23, 2006 at 12:50 AM
?? please help
Posted By: KarTuneMan
Date Posted: March 23, 2006 at 1:19 AM
I hope you got ALOT of money for sticking your neck out to put this thing in.....sometimes its NOT worth it.
Dark blu/with stripes on any of the coils...(by the spark plugs) its a 1 cyl. reading.
