99 caravan, valet 551r
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=74949
Printed Date: May 08, 2026 at 8:20 PM
Topic: 99 caravan, valet 551r
Posted By: phil1129
Subject: 99 caravan, valet 551r
Date Posted: March 23, 2006 at 3:13 AM
I bought a used 99 caravan with a dei your valet remote start. I believe the model is a 551r. When the vehicle is remote started or the ignition key is turned to the start position the horn honks. How do I disable this? I have removed the horn relay and fuse but still goes off. Thank you.
Posted By: kgerry
Date Posted: March 23, 2006 at 8:16 AM
that sounds like the factory alarm... does it do this if you are just trying to start the vehicle with the key?
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: Velocity Motors
Date Posted: March 23, 2006 at 9:06 AM
There's no HORN output on the 551R. As evin said, if the OEM security is not bypassed properly then the horn will honk and lights will flash if it's the OEM alarm. When you remote start the vehicle, try it when you have the doors unlocked ( if you have power door locks ).
------------- Jeff
Posted By: phil1129
Date Posted: March 23, 2006 at 9:47 AM
The horn does sound when I start the vehicle with the key. I did try to remote start the vehicle with the doors unlocked and it did start and the horn sounded. The van does have power door locks but it is a pretty standard van otherwise. Thanks for helping.
