page guard 8500s alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=74977
Printed Date: May 08, 2026 at 11:58 AM
Topic: page guard 8500s alarm
Posted By: trevster99
Subject: page guard 8500s alarm
Date Posted: March 23, 2006 at 2:07 PM
i got my alarm installed the other day and i noticed the the trunk is not hooked up its a power trunk id like to know what needs to be donte to hook this up or where i can look,  also my camera on my alarm will not take any pictures its a page guard 8500s im pritty sure its in the programming of it but my instructions are not very good any sugestions
Posted By: kohara73
Date Posted: March 23, 2006 at 5:08 PM
What kind of car???
Keith
Date Posted: March 24, 2006 at 8:35 PM
i got everything working but the trunk release. 03 sunfire
Posted By: Hornshockey
Date Posted: March 25, 2006 at 2:51 AM
there should be two wires coming off the back of the trunk release button. One should be BLACK/ white, a negative trigger to this wire will do the trick. Make sure you test it before you go hooking wires up.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
Date Posted: April 04, 2006 at 12:58 PM
im trying to wire up my power locks to the alarm but when i wire up the relays the way supose to it dose not work ive got the heave duty 12volt relays from canadian tire and i also got no power locks on my car but i purchesed some to work with the alarm its a pageguard alarm and the door locks came from a salvage yard they do work i tested them with the battery and the work any sugsetions
Date Posted: April 04, 2006 at 1:32 PM
https://caralarm.net/eng/img/mnu/pg-8500s.pdf thats the diagram ive been following theres only 2 wires coming from the door lock modual a grey one and a brown one
Posted By: mo12v
Date Posted: April 04, 2006 at 2:04 PM
Can't get that LINK to work..........
You will need 2 SPDT ( Single Pole Double Throw ) Relays
2 SPDT RELAYS:
NO SWITCH
Lock & Unlock from Alarm ONLY
Relay 1
LOCK:
PIN 87 =  12 Volts ( + ) Constant
PIN 87a = GROUND
PIN 30 =  wire to Positive side of Actuators
PIN 85 = Negative Lock Output from Alarm
PIN 86 = Constant 12 volt ( + )
Relay 2
UNLOCK:
PIN 87a = GROUND
PIN 85 = Negative UnLock Output from Alarm
MO
Posted By: the12volt
Date Posted: April 04, 2006 at 2:08 PM
mo12v] wrote:
P>Can't get that LINK to work..........
2 SPDT RELAYS:
NO SWITCH
Relay 1
LOCK:
PIN 87a = GROUND
Relay 2
UNLOCK:
PIN 87a = GROUND
ok now what about the rest of my wires from the alarm copy and past the link it should work that way
Posted By: mo12v
Date Posted: April 04, 2006 at 2:19 PM
What is your Question??
Are you needing ALL the wire hook up for your Alarm?
MO
Date Posted: April 04, 2006 at 2:23 PM
nono im just trying to hook up the door locks to the relays i hooked it up like it tells me in the manual but i get no response from it can you see it now theres a white wire ( 5 polarity connects to 87 on both relays but i see that it crosses the unlock dose this wire have to be hooked up to the unlock aswell or what might i be doing wrong
Posted By: mo12v
Date Posted: April 04, 2006 at 2:24 PM
The LINK you gave is for OPERATION???
MO
Date Posted: April 04, 2006 at 2:30 PM
on page 8 of 9 look for the door lock/ unlock diagram
Posted By: mo12v
If the GRAY wire Is LOCK & the BROWN wire is UNLOCK:
Relay 1
LOCK:
PIN 87a = GROUND
PIN 85 = Negative Lock Output from Alarm     GRAY
Relay 2
UNLOCK:
PIN 87a = GROUND
PIN 85 = Negative UnLock Output from Alarm   BROWN
MO
Date Posted: April 04, 2006 at 3:05 PM
ok so this way as showen in the manual will not work then and will it still work with my remote
Posted By: mo12v
Date Posted: April 04, 2006 at 3:07 PM
As I Posted...... IF ..... the GRAY wire Is LOCK & the BROWN wire is UNLOCK:
I have NOT seen your wiring and I am not familiar with that Brand Alarm....
Maybe someone else will post
MO
Date Posted: April 04, 2006 at 3:14 PM
ok your way should work then right and for the rest of my wires just tape them up
Date Posted: April 04, 2006 at 7:54 PM
mo12v] wrote:
P>If the GRAY wire Is LOCK & the BROWN wire is UNLOCK:
Relay 1
LOCK:
PIN 87a = GROUND
Relay 2
UNLOCK:
PIN 87a = GROUND
ive tried this way and all it dose is spark on the ground wire this can not be correct
Posted By: Twelvoltz
Date Posted: April 04, 2006 at 8:32 PM
On page 8 of that unit, use the top reverse polarity diagram. The one that shows pictures of actuators in it.
Gray, RED / White to ground.
White to Constant fused +12V.
Orange and Brown are your outputs to your actuators.
This is EXACTLY the same thing as mo12V wrote, except that your relays are built into your system and do not require the pin 85 connections listed in Mo's post...just look at the page, it shows on the very first diagram "Equvalent Circuit" (kind of scary when the manual is not spell checked) on the top, which wires connect to which and their corresponding relay Equivalent locations.
Good Luck,
Keep us posted.
Date Posted: April 04, 2006 at 9:38 PM
wait a sec your telling me that the grey and RED / white wire need to be grounded
Date Posted: April 04, 2006 at 9:54 PM
oh my wierd thats cool though got it to work now i just have to install them in to the door thanks allot guys what a big help
