2004 Lexus RX330 Remote Start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=74985
Printed Date: May 08, 2026 at 8:05 AM
Topic: 2004 Lexus RX330 Remote Start
Posted By: advanced
Subject: 2004 Lexus RX330 Remote Start
Date Posted: March 23, 2006 at 4:32 PM
I installed an Audiovox APS-786 remote Start/ alarm combo in this vehicle & everything is fine except the autolights stay on if you don't go out to the vehicle after remotely starting it. Does anyone know how to fix this?
Can I simply trigger the drivers door pin sw. with a negative arm pulse?
------------- Good Enough Isn't!
Posted By: doibuy
Date Posted: March 23, 2006 at 5:04 PM
Try using a factory rearm wire to the door trigger. I think that most audiovox alarms have a four pin plug with black wires with different color tracers, and one of them will be a negative pulse after shut down, either BLACK/ green or BLACK/ red, can't remember for sure which one. That should do the trick.
Posted By: kohara73
Date Posted: March 23, 2006 at 5:05 PM
That may work, as long as it doesn't set off the alarm. If it does, you may have to disarm the alarm before a remote start. ------------- Keith
Posted By: advanced
Date Posted: March 23, 2006 at 6:15 PM
Thank you both for the info. I will have to see if that sets off the alarm.
Posted By: Chris Luongo
Date Posted: March 25, 2006 at 11:04 AM
--newer Audiovox alarm/RS combos are smartly designed; they ignore the door trigger input at the beginning or end of the remote-start cycle.
--Connect the RED / black "pulse after shutdown" output to the driver's doorpin wire of the car; this will allow the autolamps to shut off once the delay period is over.
Posted By: KarTuneMan
Date Posted: March 29, 2006 at 9:04 AM
Or break the headlight wire with a relay, triggered with the ground while running. This will keep the light from coming on at all. The autolight wire is brown @ the switch.
Posted By: matt zorn
Date Posted: March 29, 2006 at 5:09 PM
use the factory alarm re-arm wire to trigger a relay that interrupts the autolight wire at the switch.
