viper 791, 2001 integra gsr, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=75008
Printed Date: May 08, 2026 at 4:15 AM
Topic: viper 791, 2001 integra gsr, remote start
Posted By: koldboi
Subject: viper 791, 2001 integra gsr, remote start
Date Posted: March 23, 2006 at 10:56 PM
i recently installed the viper 791.  everything works fine except the remote start.  i was told the remote start and the factory alarm in my 2001 acura integra 2dr gsr conflicted.  therefore i have to disarm the alarm then apply the remote start and hold the arming button for 2 seconds to activate it.  if i try the remote start while the alarm is armed, the door will unlock and the engine wont crank. any ideas will help, thank you.  Jimmy
Posted By: Twelvoltz
Date Posted: March 24, 2006 at 7:32 AM
According to DEI's techsheet the factory alarm arms and disarms only with the factory transmitter.
I am not sure what you are asking here so let's try this.
The 791 (just like most if not all DEI) requires 2 pushes of the * button to activate remote start(or pressing lock and unlock at the same time to activate timed starting mode). Since the factory alarm is only controllable via the factory remote, just make sure you have disarmed the factory alarm and put the transmitter away, just using the Viper transmitter.
Hope this helps
Keep us posted.
Posted By: Velocity Motors
Date Posted: March 24, 2006 at 7:51 AM
That doesn't sound like the OEM alarm to me. If it were the alarm, when you attempt to start the horn will honk and the lights will flash. What bypass module did you use for the Integra ? Also, it's a GS-R so did you bypass the clutch properly ? It's a (-) trigger type system for the clutch so the clutch wire requires a (-) pulse when cranking.
Posted By: koldboi
Date Posted: March 24, 2006 at 1:08 PM
i dont have a factory alarm, its just a security system in the car where the door locks i guess. but the guy who install the alarm only added a unit where i had to leave a key in it and 1 relay.  and everything else came with the viper unit. i dont think he did my clutch properly either but if i start the car manually i still have to hold down the clutch. i rather have it that way ne ways... if the hand brake his down the car wont auto start but i can start it while holding the clutch down.  he'd  put the wire/ or wires (not sure) coming from the issolator (i guess the unit with the spare key in it) around the ignition, where i stick the key in to start the car manually. he ran a wire to my e brake.  it took the dude all day to install it and half the time he was trouble shooting on why the auto start wont start.  it would only light up and make a sound with the door lock.  this is nothing like i seened b 4.
Posted By: koldboi
Date Posted: March 24, 2006 at 1:12 PM
he used a 556u bypass module and added a relay to override the clutch
Date Posted: March 24, 2006 at 2:10 PM
DEI units sold in the US are NOT for manual transmissions, they do not have the proper safety features for use in this application.
Posted By: koldboi
Date Posted: March 25, 2006 at 10:29 AM
so even with the clutch bypassed, is there a way i can use the remote start while the alarm is armed? Right now i am still disarming the alarm, remote start the car, the door now locks but the alarm doesnt arm, then holding the lock button for 2 seconds to arm it. every thing else works perfectly fine.
Posted By: Jman649916
Date Posted: March 25, 2006 at 9:22 PM
Hey everyone, this is the installer that did the remote start in this car. What's happening is somehow, the 791xv will not remote start when the system is armed. Like Jimmy said, it will turn the ignition and accessories on, but it won't crank, it just locks the doors. As you all know, the clutch uses two seperate wires to allow the vehicle to start. It is all done through one relay by breaking the first connection, and grounding the second. The wires that activate the relay are ignition +12 and ground coming from the ignition 3 output from the remote start relay module. I know, however, that the clutch bypass is not the problem because I can sit in the car with it armed, manually hold the clutch, and it still will not remote start. The E-brake wire that he mentioned is simply connected to the neutral safety switch input. This, of course is not the problem either, because if that were the problem it would not turn the ignition and accessories on. I know the starter kill relay on the alarm is not the problem, because I didn't use it. I simply connected the purple starter wire to the starter circuit. I used the 556u to bypass the key. It is connected using constant +12, ground, and the status output from the remote start relay module. If anyone has any ideas, it would be greatly appreciated.
Date Posted: March 27, 2006 at 9:47 AM
Hey everyone, I just added remote start to a previously installed 791XV in a 5 speed 2001 Acura Integra GS-R. The problem that I'm having is that when the security system is armed, the car will not remote start. It will turn the ignition and accessories on, but simply does not crank, it just locks the doors again. I can disarm the system, start it, and rearm it, but that's pretty annoying, and not pleasing to the customer.
As you all know, the clutch uses two seperate wires to allow the vehicle to start. It is all done through one relay by breaking the first connection, and grounding the second. The wires that activate the relay are ignition +12 and ground coming from the ignition 3 output from the remote start relay module. I know, however, that the clutch bypass is not the problem because I can sit in the car with it armed, manually hold the clutch, and it still will not remote start. The E-brake wire controls the neutral safety input. This, of course is not the problem either, because if it were, it would not turn the ignition and accessories on. I know the starter kill relay on the alarm is not the problem, because I didn't use it. I simply connected the purple starter wire to the starter circuit. I used the 556u to bypass the key. It is connected using constant +12, ground, and the status output from the remote start relay module. If anyone has any ideas, it would be greatly appreciated.
