2002 ford taurus
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7529
Printed Date: March 28, 2026 at 6:43 PM
Topic: 2002 ford taurus
Posted By: reitzjd
Subject: 2002 ford taurus
Date Posted: January 02, 2003 at 10:20 AM
If anyone out there knows the wiring diagram for installing a remote start system on a 02 taurus with pats security system. Any info would help. Thank You all for any help!!!
Posted By: Velocity Motors
Date Posted: January 02, 2003 at 12:37 PM
|              12V|lt. GREEN/ purple    |+  |ignition harness            |
|          STARTER|RED / lt. blue        |+  |ignition harness            |
|         IGNITION|RED / lt. green       |+  |ignition harness            |
|        ACCESSORY|gray / YELLOW         |+  |ignition harness            |
| SECOND ACCESSORY|BLACK/ lt. green     |+  |ignition harness            |
|       POWER LOCK|pink / YELLOW         |-  |26 pin plug at GEM *1       |
|     POWER UNLOCK|pink/ lt. green     |-  |26 pin plug at GEM *1       |
|       LOCK MOTOR|pink/black          |   |top plug of fusebox         |
|     UNLOCK MOTOR|RED / white           |   |top plug of fusebox         |
|    DISARM DEFEAT|pink/orange         |   |top plug of fusebox         |
| PARKING LIGHTS +|brown               |   |headlight switch or fusebox |
|       HEADLIGHTS|RED / yellow *2       |-  |headlight switch            |
|     DOOR TRIGGER|BLACK/ orange *3     |-  |20 pin plug at GEM *1       |
| DOME SUPERVISION|BLACK/ lt. blue      |+  |top plug of fusebox         |
|  TRUNK/HATCH PIN|*4                  |   |                            |
|         HOOD PIN|tan/lt. green       |-  |26 pin plug at GEM *1       |
|TRNK/HTCH RELEASE|*5                  |   |                            |
|FCTRY ALRM DISARM|pink/white          |-  |26 pin plug at GEM *1       |
|       TACHOMETER|tan / YELLOW          |   |PCM *6                      |
|      SPEED SENSE|gray/black          |   |12 pin plug at GEM *1       |
|       BRAKE WIRE|RED / lt. green       |+  |brake pedal switch          |
|     HORN TRIGGER|purple or blue      |-  |steering column             |
|           WIPERS|white(L), blu/org(H)|+  |wiper motor                 |
|  LF WINDOW UP/DN|wht/blk - org/wht   |A  |drivers window motor        |
|  RF WINDOW UP/DN|wht/yel - yel/red   |A  |drivers switch or kick panel|
|  LR WINDOW UP/DN|yel/lt blu - gry/org|A  |drivers switch or kick panel|
|  RR WINDOW UP/DN|yel/blk - RED / blk   |A  |drivers switch or kick panel|
|        RADIO 12V|                    |   |                            |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|                    |   |                            |
| RADIO ILLUMINATE|                    |   |                            |
|    POWER ANTENNA|RED / pink            |   |rear control unit *7        |
|       LF SPEAKER|lt blu/wh-org/lt grn|   |rear control unit or speaker|
|       RF SPEAKER|grn/org - wht/lt grn|   |rear control unit or speaker|
|       LR SPEAKER|tan/yel - gry/lt blu|   |rear control unit or speaker|
|       RR SPEAKER|brn/pnk - org/red   |   |rear control unit or speaker|
Notes:
NOTE: This vehicle is equipped with PATS (Passive Anti-Theft System).   *1 The GEM module is to the left of the steering column.  *2 The headlights are high current negative. Must use a relay.  *3 This wire controls the door ajar indicator on the dash, must cut the wire and diode isolate it from the instrument cluster. Can also use individual negative door trigger wires in the 26 pin plug at the GEM. They are: yellow/black (LF), gray/red (RF), lt. GREEN/ YELLOW (LR), and pink/lt blue (RR).  *4 On the sedans use BLACK/ pink (-) at the light in the trunk. On the wagons use WHITE/ purple (-) in the 26 pin plug at the GEM.  *5 With keyless entry it is purple / YELLOW (-) at the switch. Without keyless entry it is gray/red (+) at the switch. On the wagon, to unlock just the rear hatch use yellow/lt. green (-) in the 26 pin plug at the GEM.  *6 The PCM is on the passenger side firewall under the hood.  *7 The rear control unit is on the left side of the trunk.
