siren wires
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=75309
Printed Date: May 06, 2026 at 1:00 AM
Topic: siren wires
Posted By: scream404
Subject: siren wires
Date Posted: March 29, 2006 at 12:23 PM
i have a dei siren in my car, what are the two extra loop wires coming from the siren itself used for?
Posted By: cguys
Date Posted: March 29, 2006 at 12:42 PM
i just asked this question a few weeks ago ..... most memebers lik eit if you search for an answer first , but i dont care , the answer i got from the same question was that its a loop for the volume when your siren chirps for arm and disarm . cut the loop and its full volume .
Posted By: black78ta
Date Posted: March 29, 2006 at 1:28 PM
The BLACK/ white wire is for allowing the siren to cycle through all the different sounds while the alarm is going off. Cut the BLACK/ white wire if you just want the hi/lo siren sound. The black wire is for softening the chirp when arming/disarming the alarm. Cut the black wire if you want the chirp to be louder.
