Momentary switch
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=75864
Printed Date: April 27, 2026 at 12:15 PM
Topic: Momentary switch
Posted By: Red97LT1
Subject: Momentary switch
Date Posted: April 07, 2006 at 7:43 PM
The keyless entry in my wifes car went out,so I decided to put in another keyless entry w/ an alarm.Eveything is fine,except the guy who did the previous install put a momentary switch in the middle console to lock/unlock the doors.How do I go about wiring it up so I can still use it? It has three wires,blk,grn,blue. Thanks
Posted By: doibuy
Date Posted: April 07, 2006 at 11:40 PM
Do you have aftermarket door lock actuators?  I'm guessing so, other wise you wouldn't have a switch in the console, just the factory switches.  The switch probably is a simple lock switch, I would guess that the black wire would go to ground, then your green would be lock and blue would be unlock. These would send a pulse to a relay pack triggering your door locks.
Posted By: Red97LT1
Date Posted: April 10, 2006 at 6:06 PM
If you go here https://www.google.com/search?q=BW-852 and click the fourth link,you'll see how the door lock actuators are wired?
Posted By: Powermyster
Date Posted: April 10, 2006 at 6:18 PM
your keyless works off an internal relay.. if the locking is positive or negatively controlled.
you will hook one wire off the switch to pos or neg depending how your locking is activated. and the other 2 will go to the lock and unlock.
you will have to test continuity on the switch to find out what wire does what.
1 wire is input the other 2 and switched outputs
Why oh Why didn't i take the blue pill
Darren Power
Posted By: Red97LT1
Date Posted: April 10, 2006 at 6:34 PM
The locks are negative.
Date Posted: April 10, 2006 at 6:35 PM
just have to ground the input wire and put the other wires to your locking
Darren Power
Posted By: Red97LT1
Date Posted: April 10, 2006 at 6:50 PM
Forgot to mention that the actuators are a 5-wire setup if that makes a difference.
Date Posted: April 11, 2006 at 4:39 AM
no. if the alarm can open and close with a a neg so can the switch top into the alarm wires
Darren Power
