98 blazer no yellow wire on passlockII
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=75972
Printed Date: April 28, 2026 at 11:22 PM
Topic: 98 blazer no yellow wire on passlockII
Posted By: carlos gonzalez
Subject: 98 blazer no yellow wire on passlockII
Date Posted: April 09, 2006 at 9:58 PM
1998 chevrolet blazer
I'm trying to find the r-code to bypass the passlock II with relays I'm installing a remote start I got two wires coming from ignition lock one black and the other GREEN / WHITE  my question is which one is suppose to be the yellow one I got a diagram and is suppose to be a yellow wire and a blck or ORANGE / black I did before a 98 1500 that was a piece of cake  to find the r-code because that one has the yellow wire  now I'm getting a lot of trouble to find it  on the blazer I did cut the GREEN / WHITE and put the digital multimeter and show me infinite resistance with the key on,start even with the key out can someone help me on this one
thank you
Posted By: NowYaKnow
Date Posted: April 09, 2006 at 10:10 PM
Sounds like you found the shifter position harness, not the passlock harness. The harness you want will have RED / white, yellow, and ORANGE / black wires in it.
Mike
Date Posted: April 09, 2006 at 10:15 PM
well those two wires are coming from the ignition lock cylinder no others wires around unless the ones coming from ignition switch
southtech
Posted By: Twelvoltz
Date Posted: April 10, 2006 at 7:11 AM
As Mike has already stated, you have found the wires that allow the shifter to go into gear. Keep looking, they are there. Take off the plastic shroud under the column and you will see them easily.
Keep us posted.
Date Posted: April 10, 2006 at 7:53 AM
ok  I will check  that  I was doing that fast and never took of the shroud I just look for a hole  on the shroud and I sold those wires coming from the lock  so there must be another pair of wires .
I will tell you if I find the yellow one around and thanks for your comments
southtech
Posted By: customak47
Date Posted: April 13, 2006 at 6:14 PM
It's possible the car is actually a 97 and doesn't have passlock on it. Do you have a theft or security light on the dash when you turn the key on? If not, try remote starting it. Otherwise, those three wires ARE there somewhere close to the key cylinder. white yellow black or RED / white yellow, ORANGE / black. Good luck
My rifle is my friend...
Posted By: extreme1
Date Posted: April 13, 2006 at 6:47 PM
IF YOU grab the ignition harness as it comes out of the steering wheel shroud, they will be there, you'll have your main ign wires, a smaller yellow and white that are starter and ign 2, and an even smaller yellow, RED / white and ORANGE / black.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Date Posted: April 13, 2006 at 6:50 PM
it is a 98  I found the wires the thing was a never took off the cover that was the reazon why can't see the wires the other ones are the shifter position harness
southtech
Date Posted: April 13, 2006 at 7:01 PM
after that just took me 10 minutes to finish it now I know  doing it fast is not good idea I can lose more time that doing it slow. thanks for your help.
southtech
