95 pontiac keyless entry broke
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=75982
Printed Date: April 29, 2026 at 5:22 AM
Topic: 95 pontiac keyless entry broke
Posted By: daltroyaik
Subject: 95 pontiac keyless entry broke
Date Posted: April 10, 2006 at 12:12 AM
PLEASE HELP MY KEYLESS ENTRY STOPPED WORKING AND I CANT FIGURE OUT HOW TO FIX IT.  MY REMOTES HAVE NEW BATTERIES AND WHEN I START MY CAR THE DOORS LOCK LIKE IT WAS WORKING.  BUT WHEN I TRY TO USE THE REMOTE TO LOCK OR UNLOCK IT DOESNT WORK.  WHAT ARE THE ODDS THAT BOTH REMOTES GO BAD AT THE SANE TIME?  SLIME AND NONE I THINK.  I CANT FIND THE MAIN BOX TO SEE WHERE THE KEYLESS IS COMING FROM.  CAN ANYONE HELP ME PLEASE???  THANKS KYM  :x
KYM
Posted By: swamprat323
Date Posted: April 10, 2006 at 12:16 AM
first turn off the dam caps.
is this a factory or after market keyless.
Date Posted: April 10, 2006 at 12:19 AM
Sorry about the caps.  It is after market...My remote says "Your Valet"  So i am assuming they are the makers.  Thank you Kym
KYM
Date Posted: April 10, 2006 at 1:56 PM
does any other buttons work, like panic or trunk pop.
Date Posted: April 10, 2006 at 2:21 PM
Nothing on the remote works at all.  i have 2 remotes and nothing is working.  Thanks Kym
KYM
Posted By: xtremej
Date Posted: April 10, 2006 at 2:32 PM
Its made by DEI they produce valet products. Did you have a dead battery in your car lately? Are the leds/green lights illuminating on the remotes? Some cars Have factory ignition controlled locks, I am not sure on this model.  Sounds unlikely both remotes would go bad at the same time though...You'll also want to locate the brain this is were most of your testing will be done. I'm betting its somewhere under the drivers side dash.....
