CS-2016DPFM Remote Start in 96 Altima
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=76023
Printed Date: April 29, 2026 at 3:36 AM
Topic: CS-2016DPFM Remote Start in 96 Altima
Posted By: JdM xplod b01
Subject: CS-2016DPFM Remote Start in 96 Altima
Date Posted: April 10, 2006 at 5:14 PM
I just installed my crimestopper CS-2016DPFM in my 1996 nissan altima. I did all the basic stuff, locks, triggers, start disable, etc. . . everything works but i need to know what wires i need to do the remote start. Im thinkin i need to find starter wire, tach (negative on coil ?), and brake wire. Can som1 tell me the colors to these and where i can find them? Also is there any other thing i will need to know to install remote start?
------------- Pioneer Premier TS-w3004spl, Bass Slammer vented, Kenwood KDC MP-4028, and a KAC-9152d.
Posted By: prdjr165
Date Posted: April 10, 2006 at 5:30 PM
for remote start you need:
MODEL YEAR(S)
ALTIMA 1993 -1997
KEY T-HARNESS IMMOBILIZER
N/A NIS-2 N/A
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT WHITE/ RED to WHITE (+) IGNITION SWITCH HARNESS
STARTER BLACK / YELLOW to BLACK/ WHITE (+) See NOTE *1 IGNITION SWITCH HARNESS
STARTER 2 BLACK/ GREEN to BLACK / YELLOW (+) See NOTE *1 IGNITION SWITCH HARNESS
IGNITION 1 BLACK/ WHITE to BLACK/ RED (+) IGNITION SWITCH HARNESS
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY /HEATER BLOWER 1 RED to BLACK/ PINK (+) See NOTE *2 IGNITION SWITCH HARNESS, See DIAGRAM 26500_ALTIMA_NISSAN ACCESSORY ISOLATION CIRCUIT.pdf
ACCESSORY /HEATER BLOWER 2 N/A
KEYSENSE N/A
PARKING LIGHTS ( - ) N/A
PARKING LIGHTS ( + ) RED / BLUE (+) @ STEERING COLUMN HARNESS
POWER LOCK GRAY/BLUE (TYPE B) @ DOORLOCK TIMER, See NOTE *3
POWER UNLOCK GRAY/RED (TYPE B) @ DOORLOCK TIMER, See NOTE *3
LOCK MOTOR WIRE N/A
DOOR TRIGGER RED / WHITE (-) IN DRIVERS KICK PANEL
DOMELIGHT SUPERVISION USE DOOR TRIGGER
TRUNK RELEASE N/A
SLIDING POWER DOOR N/A
HORN GREEN / WHITE (-) @ STEERING COLUMN HANRESS
TACH GREEN @ IGNITION COIL
WAIT TO START LIGHT N/A
BRAKE RED / GREEN (+) @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM GREEN/ YELLOW (-) IN DRIVERS DOOR HARNESS
ANTI-THEFT N/A
NOTES
NOTE *1 When Installing a REMOTE STARTER, you MUST use BOTH Starter #1 and Starter #2 wires. Both wires must be connected to the STARTER/CRANKING Output wire from the Remote Starter or the vehcile will NOT Remote Start when the Engine is cold.
NOTE *2 THIS VEHILES ACCESSORY WIRE MUST BE ISOLATED FOR REMOTE STARTING AND REQUIRES AN EXTRA RELAY PART #775, TO CONNECT, See DIAGRAM
NOTE *3 TIMER MODULE IS A BLACK OR GREEN BOX LOCATED RIGHT OF FUSEBOX, BEHIND A SILVER MODULE OR, UP HIGH IN THE DRIVERS KICK PANEL, BEHIND A SILVER MODULE, DEPENDING ON THE MODEL. THERE ARE 2 PLUGS, WHITE AND BLACK. THE WIRES NEEDED FOR THE LOCKS ARE IN THE BLACK PLUG.
Date Posted: April 10, 2006 at 7:20 PM
I am still confused on which wires i need for the remote start.
Posted By: Twelvoltz
Date Posted: April 10, 2006 at 7:40 PM
The Ignition, both Starters, Accessory wire, are required to get the vehicle to run, brake wire is needed to shut down the starter. Tachometer is a good idea, it makes it more reliable, but the system can work in voltage sensing as well. Hood pin is a good idea, as well as neutral safety switch wire. Pay close attention to the accessory wire as well, it needs to be isolated from the switch when remote starting.
Hope this helps
Keep us posted
Date Posted: April 10, 2006 at 9:49 PM
Thanks for clearin it up, but is accessory absolutly required? It looks like a pain in the a to do.
Date Posted: April 11, 2006 at 7:02 AM
It really depends on the vehicle, but most require at least the one accessory to power the blower motor for heat and A/C. It is not a pain to do at all, if you have done the starter kill already, it is very similar.
Date Posted: April 11, 2006 at 1:48 PM
So basicly accessory is for the heater or ac to be on during remote start?
Date Posted: April 11, 2006 at 1:50 PM
Yes, it is. This connection may also power ABS/Airbag control modules in some vehicles.
Date Posted: April 13, 2006 at 3:36 PM
OK, i got the remote start to work, but after i drive the car i have to use the remote to turn the car off. How can i turn the car off with the key?
Date Posted: April 13, 2006 at 5:51 PM
Hook up your brake wire. This tells the remote start when to shut down.
