Compustar, Clifford Proximity Sensor?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=76025
Printed Date: April 29, 2026 at 1:58 AM
Topic: Compustar, Clifford Proximity Sensor?
Posted By: mb07
Subject: Compustar, Clifford Proximity Sensor?
Date Posted: April 10, 2006 at 5:58 PM
I'm going to be adding a Clifford Proximity Sensor to a 2WFM -AS compustar.  now this proximity sensor wants power, ground and the last wire wants to go to Sensor Input (-)  where exactly is that on the compustar.  How would I hoook up that last wire.  Any help is appreciated.   Thanks..
Posted By: Powermyster
Date Posted: April 10, 2006 at 6:01 PM
to any of the neg triggers on the alarm.
if its dual stage with 3 wires it can only do full trigger or warn away on the compustar as it is a multiplex sensor. a .8 second pulse or less is for warn away and over .8 is full trigger on the clifford alarm..
i would tie the sensor into the shock sensor trigger wires
Why oh Why didn't i take the blue pill
Darren Power
Posted By: mb07
Date Posted: April 10, 2006 at 6:14 PM
So even the (-) dome light trigger?  Like what I have the doors hooked up to?  Just like that?
Date Posted: April 10, 2006 at 6:21 PM
just like that!
the will just be a full trigger with no warn away
and diagnostic will how the door trigger as being the cause of the alarm.. not prox
Darren Power
Posted By: mb07
Date Posted: April 10, 2006 at 7:06 PM
hmmm warning though does sound more practical then a automatic alarm going off.. posted_image
Date Posted: April 11, 2006 at 4:36 AM
is it a dual zone sensor with 3 wires..
Darren Power
Posted By: OhioMike1101
Date Posted: April 11, 2006 at 8:04 AM
Why not get a prox that will work with the compustar? The 2w900fm has an extra set of sensor inputs for 1st and 2nd stage.
South Side Audio
2501 S. High St
Columbus, OH 43207
Date Posted: April 11, 2006 at 8:06 AM
that would be ideal mike.
i would go with that. but he already have the clifford one.
Darren Power
Posted By: mb07
Date Posted: April 11, 2006 at 9:49 AM
This compustar has a little red plug with 2 wires and that whole plug is called "optional sensor"  Ia that what you guys are talking about?
Date Posted: April 11, 2006 at 10:07 AM
yes they are just the trigger connection though think you have to power the sensor seperately.. not sure don't do compustar
Darren Power
Date Posted: April 12, 2006 at 7:52 AM
The clifford won't work as it is multiplexed. You can only have it be 1st or 2nd stage. You can't have both.
I would get a dfferent prox.
South Side Audio
2501 S. High St
Columbus, OH 43207
Date Posted: April 12, 2006 at 9:04 AM
thats what i said..
sell teh clifford prox and buy a compustar one.. best solution all round
Darren Power
