2000 Mustang alarm, no start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=76090
Printed Date: April 27, 2026 at 7:49 PM
Topic: 2000 Mustang alarm, no start
Posted By: djtsmith007
Subject: 2000 Mustang alarm, no start
Date Posted: April 11, 2006 at 7:20 PM
IM trying to install a Carbin 4700 plus alarm on my 2000 mustang, v6. And im having trouble with the wiring into the factory alarm. What if anything, do i need to get to bypass that? Im not putting in a remote start, just a typical alarm. Ive tried everywhere lookin for help. Thanks ahead!
Posted By: mo12v
Date Posted: April 11, 2006 at 9:15 PM
12volts yellow & lt. GREEN/ purple  +  ignition harness
Starter WHITE/ pink  +  ignition harness
Ignition RED / lt. green  +  ignition harness
Power Lock lt. green  +  20 pin plug, pin 20 at GEM
Notes: The GEM (Generic Electronic Module) is located above the driver kick panel.
Power Unlock purple  +  20 pin plug, pin 18 at GEM
Lock Motor RED / white  5wi 20 pin plug, pin 9 at GEM
Unlock Motor RED / orange  5wi 20 pin plug, pin 7 at GEM
Disarm Defeat pink/orange  5wi 20 pin plug, pin 8 at GEM
Parking Lights+ brown  +  26 pin plug, pin 7 at GEM
Parking Lights- WHITE/ black  -  26 pin plug, pin 11 at GEM
Hazards same as turn signals
Turn Signal(L) lt grn/wht(F), lt grn/org(R)  +  steering column
Turn Signal(R) wht/lt blu(F), org/lt blu(R)  +  steering column
Door Trigger yel/black (L), gray/red (R)  -  20P plg, pin 13 & 5 at GEM
Notes: Use yellow/black for the driver door trigger and gray/red for the passenger door. Use both wires and diode isolate each from the GEM module, refer to DirectFax document 1076 for wiring information.
Dome Supervision BLACK/ white  +  20 pin plug, pin 3 at GEM
Trunk/Hatch Pin BROWN / white  -  12 pin plug, pin 3 at GEM
The hatch pin needs to be diode isolated from the GEM module. Refer to DirectFax document 1076 for wiring information.
Hood Pin N/A
Trunk/Hatch Release pink/lt. green  -  26 pin plug, pin 25 at GEM
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm dk. GREEN/ purple  -  20 pin plug, pin 16 at GEM
Disarm No Unlock see factory alarm disarm
Tachometer NOT red or WHITE/ lt. blue  ac  ignition coil or coil pack
Horn Trigger yellow/lt. green  -  26 pin plug, pin 12 at GEM
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
posted_image
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
PATS
Part #: 555PW
Alternate Part1 #: 555FW
Alternate Part2 #: 556UW
MO
Posted By: bmwpwner
Date Posted: April 16, 2006 at 12:41 AM
you need the factory disarm wire off the above tech sheet. you can either use the factory disarm wire off your aftermarket alarm to pulse this wire (if you alarm is equipped with such an output) or you can diode isolate the unlock wire to pulse the factory alarm disarm wire as well. if you can't find the factory disarm wire in the vehicle sometimes you can use a pulse before unlock/disarm to a relay to trigger the ignition wire in the vehicle to "wake" the vehicle up. i had to do this on a taurus i did awhile back and got the setup from DEI techs. worked great but haven't had to do it since then on any other vehicles but i'm assuming it would work on anything that needed to disarm the OEM alarm to be able to unlock the vehicle. good luck and hope this helps.
"I cannot teach anybody anything, I can only make them think."
-Socrates-
