dei 530t one touch only in driver switch
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=76128
Printed Date: April 27, 2026 at 12:13 PM
Topic: dei 530t one touch only in driver switch
Posted By: sufferrar
Subject: dei 530t one touch only in driver switch
Date Posted: April 12, 2006 at 1:34 PM
I have installed 2 530ts in my 2003 frontier .i installed both in the driver door. i used the wires according to the vehicle wiring colour code for the windows. Every thing works except that you only get the one touch feature from the drivers control switches. the rest of the door switches work like factory with the one touch. will i have to go into each door for the one touch to work?
------------- "I'm So Loud It Hertz"
Date Posted: April 12, 2006 at 1:37 PM
sorry, meant to say : the rest of the door switches work like factory without the one touch.
Posted By: infinkc
Date Posted: April 12, 2006 at 2:32 PM
the module since its only in the drivers door, will only have the one touch for the driver(connected to the drivers door switch). only way to go around that is run a wire from the module to each door switch.
------------- There are 10 types of people in the world, ones that understand binary and ones that dont.
Date Posted: April 12, 2006 at 2:39 PM
I guess that the vehicle wiring colour code in the data base needs to alert installers that you need to go into each door for the one touch. I had the assumption that it will work on all doors...
Posted By: infinkc
Date Posted: April 12, 2006 at 6:15 PM
its not the wiring databases fault, its the module manufacture that should note that, in any car it will be the case that it only works one touch from the drivers side unless the car is a 2 door with a centraly mounted window switch (like bmw)
Posted By: mthill25
Date Posted: April 19, 2006 at 1:54 PM
The 530t manual does state that it needs to be wired between the switch and motor for the one touch to work. Just did mine last night.
