Clifford Solaris remote start problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=76194
Printed Date: April 27, 2026 at 9:28 PM
Topic: Clifford Solaris remote start problem
Posted By: buickgs455
Subject: Clifford Solaris remote start problem
Date Posted: April 13, 2006 at 9:16 PM
Hello, I'm new here trying to figure out what the problem is with my Solaris Remote Start alarm installed on a 99 Honda Civic SI. Basically, the car developed this problem a day ago and since then it is not functioning correctly. The LED light flashes 10 times telling me low battery voltage or a power tampering problem. I replaced the battery, and checked the connections; they all look brand new.
The problems: I can start the car with remote start, it will run fine. But, when I unarm it, the car immediately shuts everything down. It also does not let the accessories "run-on" until I open the door as usual. Only about 1/2 the time will it actually give me the 10-flash LED code, but the problem is everytime. I can't make any sense of what power-tampering means or how to fix it. Any help would be greatly greatly appreciated.
Chris
Austin, TX
Posted By: dea,can
Date Posted: April 14, 2006 at 3:58 AM
As you say the connections look brand new now was this just installed by a shop or your self if a shop has done the install take it back and if u have done check all your connections or when did it start acting up on you it my be a bad unit.
dragon
