Hornet 745T into 97 Civic
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=76699
Printed Date: March 25, 2026 at 1:47 PM
Topic: Hornet 745T into 97 Civic
Posted By: skrewdriver88
Subject: Hornet 745T into 97 Civic
Date Posted: April 23, 2006 at 10:42 PM
I just installed my Hornet 745T into my 97 Civic HX and it all works good.  But im not sure which color wires i splice into to connect the Starter Interrupt/Output.  What color wire in my ignition do i tap into for the Starter Motor/Relay and what color wire do i tap into for the Key Side of Starter?
Posted By: infinkc
Date Posted: April 23, 2006 at 11:04 PM
its the same wire, you will be cutting it, the black white wire. one side goes to each of the cut wire ends
There are 10 types of people in the world, ones that understand binary and ones that dont.
Date Posted: April 24, 2006 at 6:28 AM
So i take it the BLACK/ white wire is in the ignition harness correct?
Posted By: infinkc
Date Posted: April 24, 2006 at 8:29 AM
yes correct, coming from the ignition switch.
