DEI 530T Window Modules and a 2000 GM Truck?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7674
Printed Date: April 01, 2026 at 11:01 PM
Topic: DEI 530T Window Modules and a 2000 GM Truck?
Posted By: Truck00
Subject: DEI 530T Window Modules and a 2000 GM Truck?
Date Posted: January 05, 2003 at 10:39 AM
I am having trouble installing the DEI Window modules in me 2000 GM Truck. Does any one know where I can get a wiring diagram or some instructions? Do the modules need to be diode or have a relay put in a special place? can anyone help?? Thanks,
Posted By: Velocity Motors
Date Posted: January 05, 2003 at 10:48 AM
DEI 530T | LF WINDOW UP/DN|blue - brown |A |drivers door switch | | RF WINDOW UP/DN|blue - brown |A |passenger door switch ------------- Jeff
Posted By: securinu
Date Posted: January 05, 2003 at 11:58 AM
what jeff said but to add on you will need to go into each door and get the wires between both switches and motors in the respective door.
Posted By: gmc4x4
Date Posted: January 14, 2003 at 2:24 PM
do you have to tear into both doors, or can you just use the drivers door wire harness since it contains all needed wires?? am going to install window module on a 97yukon in the near future.. -------------
Date Posted: January 14, 2003 at 3:27 PM
Just access the wires in the driver's door. It will control the passenger side as well.
------------- Jeff
Posted By: nissanserautox
Date Posted: January 14, 2003 at 6:04 PM
I did a 2002 Youkon Denali, had to go to every door with the DEI system.
Posted By: auex
Date Posted: January 14, 2003 at 6:41 PM
Some of the newer chevy trucks no longer run motor wires across the car. When Techsoft says to go to each door it means that the wires coming from the drivers door are just a low level switch going into the passengers door switch. I don't know about the 2000 but the 2002 are all this way.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
