2004 Kia Rio alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=76865
Printed Date: April 02, 2026 at 2:45 PM
Topic: 2004 Kia Rio alarm
Posted By: armegedon667
Subject: 2004 Kia Rio alarm
Date Posted: April 26, 2006 at 11:14 PM
I need some wiring info for installing a full featured alarm in a 2004 Kia Rio. Anyone have any info?
Posted By: another-kelly
Date Posted: April 26, 2006 at 11:49 PM
KIA RIO 2004
| 12volts | blk/blue (30A), grn/red (30A) | + | ignition harness | | Starter | blue | + | ignition harness | | Second Starter | N/A | | | | Ignition | blue/red | + | ignition harness | | Second Ignition | blue/black | + | ignition harness | | Third Ignition | N/A | | | | Accessory | RED / blue | + | ignition harness | | Second Accessory | N/A | | | | Keysense | blue | + | ignition harness | | Power Lock | red | - | relay high in driver kick | | Power Unlock | yellow | - | relay high in driver kick | | Lock Motor | blue | 5wi | relay high in driver kick | | Unlock Motor | green | 5wi | relay high in driver kick | | Parking Lights+ | RED / green (L), blue/black (R) | + | driver kick, harness to rear | | Parking Lights- | GREEN/ blue | - | headlight switch or ETWIS | | Hazards | same as turn signal wires | | | | Turn Signal(L) | GREEN/ YELLOW | + | turn signal switch | | Turn Signal(R) | GREEN / WHITE | + | turn signal switch | | Reverse Light | blue/black | + | driver kick, harness to rear | | Door Trigger | GREEN/ red | - | ETWIS high in driver kick | | Dome Supervision | white | - | ETWIS high in driver kick | | Trunk/Hatch Pin | lt. GREEN/ red | - | ETWIS high in driver kick | | Hood Pin | lt. GREEN/ YELLOW | - | ETWIS high in driver kick | | Trunk/Hatch Release | N/A | | | | Power Sliding Door | N/A | | | | Factory Alarm Arm | factory remote only | | | | Factory Alarm Disarm | factory remote only | | | | Disarm No Unlock | | | | | Tachometer | BROWN / red | ac | ECM or diagnostic plug | Notes: The ECM is in the driver kick panel. The tach wire is in pin 31 in the 52 pin plug.
Can also find the tach wire in the diagnostic plug behind the driver side headlight. | | Wait to start | N/A | | | | Brake Wire | RED / black | + | brake pedal switch | | Parking Brake | blue/white to blue/black | - | driver kick, harness to rear | | Horn Trigger | lt. GREEN/ red | - | horn switch | | Memory Seat 1 | N/A | | | | Memory Seat 2 | N/A | | | | Memory Seat 3 | N/A | | |
| Interface Module: | Category: Immobilizer Bypass | Required: No |
