wiring relays for RKE
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=76893
Printed Date: April 02, 2026 at 6:00 PM
Topic: wiring relays for RKE
Posted By: laser4g63
Subject: wiring relays for RKE
Date Posted: April 27, 2006 at 1:52 PM
HI,
I need some help on how to wire some relays to make use of the horn output (-) on my Crimestopper RKE.  What I need help with is how to wire the relays so I can provide power to the horns as well as having the RKE activate them when locking/unlocking the doors.  I have a 92 Plymouth Laser AWD.  Diagrams would be best.  Thanks for the help.
Craig
Posted By: Twelvoltz
Date Posted: April 27, 2006 at 2:32 PM
DEI lists this note regarding the horn trigger in your vehicle " Steering column wire is neg. on GREEN/ black. The other side of the horn rests at ignition on GREEN / WHITE. Find GREEN / WHITE at fuse box, fuse number 10, 10 amp. Use two relays, one to throw pos. to GREEN / WHITE and one to throw neg. to GREEN/ black at steering column." You will have to use 2 relays, one for positive output, one for negative output, both activated by negative triggers.
Relay 1:
Pin 85 = - horn output from Crimestopper
Pin 86 = Constant fused +12V
Pin 30 = Constant fused +12V
Pin 87 = Positive output to GREEN / WHITE in vehicle
Relay 2:
Pin 30 = Ground
Pin 87 = Negative output to GREEN/ black in vehicle
Hope this helps
Date Posted: April 27, 2006 at 9:07 PM
Thank you.  I figured it out 15 minutes after I posted this.  Luckily I did it the same way you posted to do it.  Again, thanks.
Craig
