5 wire reverse question
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=76896
Printed Date: April 02, 2026 at 6:00 PM
Topic: 5 wire reverse question
Posted By: reganswan
Subject: 5 wire reverse question
Date Posted: April 27, 2006 at 3:38 PM
Wiring up a keyless, everytime I hit the remote, it blows the fuse on the power feed to the relays....and of course the locks dont do a thing.  Using a keyless with negative outputs only.
Posted By: mo12v
Date Posted: April 27, 2006 at 5:12 PM
Would be great if you Posted more info on Vehicle:
Be sure you are using SPDT Relays:
2 SPDT RELAYS:
Cut LOCK  & UNLOCK Wire in Half.
One Half goes to SWITCH
One Half goes to ACTUATOR
Relay 1
LOCK:
PIN 87 =  12 Volts ( + ) Constant
PIN 87a =  wire from Door Lock Switch
PIN 30 =  wire to Actuator
PIN 85 = Negative Lock Output from Alarm
PIN 86 = Constant 12 volt ( + )
Relay 2
UNLOCK:
PIN 87a =  wire from Door UnLock Switch
PIN 85 = Negative UnLock Output from Alarm
MO
Posted By: Ravendarat
Date Posted: April 27, 2006 at 9:27 PM
if you already wired the relays in then I would suspect that you have the wires comming from the relay to motor/switch reversed
