519H, how-to Garage Door
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=77085
Printed Date: May 11, 2026 at 5:30 AM
Topic: 519H, how-to Garage Door
Posted By: hamzter
Subject: 519H, how-to Garage Door
Date Posted: May 01, 2006 at 12:06 AM
Just joined the group and did my research here. Tried searching through google and the local forum search engine and got Vague results on what I would like to do.
So, I just got a DEI 519H convenience module I think that is what it is. I was not sure if the module get hooked up to my garage door swtich on the wall or if it gets hooked up in my car and then controls my garage door opener. I was hoping that I can connect it directly to my garage door switch instead so I can free up the garage door opener. Will I need a relay for this module as well?
If this is true, what gets connected to what on channel one output. Sorry for being the NEWBIE here, but any help would greatly be appreciated.
This is an image of what I got.
posted_image
Thank you for the help.
Mark "Hamzter" Cinense
1991 Infiniti G20 w/JDM SR20DE
Eclipse CD8445
MTX Thunder 684
Polk DB6750
Polk DB6500
Optima Red Top in the Trunk
Posted By: infinkc
Date Posted: May 01, 2006 at 11:25 AM
hooks up next to your garage door opener, plugs in using a power transformer. You program it to your remote for your car and it will activate it. no relay needed.
There are 10 types of people in the world, ones that understand binary and ones that dont.
Posted By: hamzter
Date Posted: May 01, 2006 at 1:47 PM
Thank you. I greatly appreciate the reply. When I use just channel one on the module, do I hook up only one wire from channel on eon the 519H module?
Eclipse CD8445
MTX Thunder 684
Polk DB6750
Polk DB6500
