1978 mercedes
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7710
Printed Date: April 02, 2026 at 5:15 AM
Topic: 1978 mercedes
Posted By: mobiletoys2002
Subject: 1978 mercedes
Date Posted: January 05, 2003 at 10:43 PM
ok i got to do this car and it is a little crazy there is  no where to catch the ignition wires easily it looks like can someone help me please.. Also this car has a crazy acting door the drivers door switch does not work but the door only locks with the key from the passenger side whats with this can i add the actuator in the passanger door??? please guys give me some tips for this car it seems to be a pain for a remote start install!!!!
Posted By: Velocity Motors
Date Posted: January 05, 2003 at 10:49 PM
Here is some information on a 1979 Mercedes 450 SL. You can use some of the information as reference colors and test the other's with a DMM. The door locks you will need an actuator:
|              12V|red                 |+  |at fuse box in pass.        |
|          STARTER|PURPLE / white *1     |+  |kick panel. Make sure       |
|         IGNITION|RED / black           |+  |to locate large gauge       |
|        ACCESSORY|RED / green           |+  |wires from key.             |
|       POWER LOCK|add actuator        |   |driver's door               |
|     POWER UNLOCK|add actuator        |   |                            |
| PARKING LIGHTS +|gray, gray/white    |   |lt. switch *2               |
|       HEADLIGHTS|WHITE/ yellow        |+  |at light switch *2          |
|     DOOR TRIGGER|BROWN / gray          |+  |either pin or ctsy lt.      |
|  TRUNK/HATCH PIN|*3                  |   |at trunk switch/light       |
|       TACHOMETER|                    |   |                            |
|       BRAKE WIRE|BLACK/ red           |+  |brake switch                |
|     HORN TRIGGER|BLACK / YELLOW/pink   |+  |st. column harness          |
|  LF WINDOW UP/DN|green, black        |   |switches in console         |
|  RF WINDOW UP/DN|grn/yel, blk/wht    |   |                            |
Notes:
*1 Starter wire goes to a relay located just above the fuse panel. Also locate at a terminal strip on the passenger side inner fender.  *2 The light switch removes by pulling the knob straight off (do not break the little bulb inside) and unscrewing the big nut. Under the rubber boot on the back of the switch are screw terminal connections. ALso find gray/red and gray black wires at the fuse box.  *3 Solder wire directly to switch contact at light/switch fixture.
