1999 Honda CRV, alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=77156
Printed Date: May 10, 2026 at 8:27 PM
Topic: 1999 Honda CRV, alarm
Posted By: dxdenis02
Subject: 1999 Honda CRV, alarm
Date Posted: April 29, 2006 at 10:51 AM
no relay needed take the ign wire cut it in half now you have two wires a key side and a coil side butt connect or soilder immobiliser circuit no 2 (the alarm wires should be labled key side .....coil side. the key side is the wire that goes to the key , remember you just cut the wire) starter is the same thing might be called key side .... motor side the fuel pump same concept except the wire might be towards the rear of the car sorry im not fimilar with that vehical i cant spell either lol
Posted By: boomer_106
Date Posted: April 29, 2006 at 10:58 AM
The ignition loom is the group of wires that runs generally from the key cylinder down the steering wheel to the iginition switch. Look up under your steering column for the wires you need. For the immobiliser circuits you don't need to connect all 3 of them unless you are extremely worried about your car being stolen. Most people just do the starter kill. This link shows you diagrams for those. https://www.the12volt.com/relays/page2.asp Your manual should explain how to connect those systems. Unless you have an onboard relay then you usually do need one. If your book says something to the effect of 200ma - output then you need to use a relay. Good luck. Keep us updated
Posted By: infinkc
Date Posted: May 01, 2006 at 10:36 PM
WIRING INFORMATION - HONDA / HRV (UK) / 1999 / Remote Start
12volts Starter BLACK/ white ignition harness Second Starter Ignition BLACK / YELLOW ignition harness Second Ignition Third Ignition Accessory Second Accessory Keysense Power Lock WHITE/ red 5wi CDL unit, driver underdash Power Unlock yellow/red 5wi CDL unit, driver underdash Lock Motor Unlock Motor Parking Lights+ grn/red & grn/yel steering column Parking Lights- Hazards Turn Signal(L) Turn Signal(R) Reverse Light Door Trigger GREEN/ red - CDL unit, driver underdash Dome Supervision Trunk/Hatch Pin blue/black CDL unit, driver underdash
------------- There are 10 types of people in the world, ones that understand binary and ones that dont.
Posted By: mad550
Date Posted: May 02, 2006 at 5:50 AM
Ign wire should be active while cranking the car, if you don't connect it then the alarm won't know to Immobilise when someone accually tries to steal the car
------------- WOW Sight and Sound
Maroochydore
Nothing is impossible!
Do it right the first time or don't do it at all.
Posted By: Twelvoltz
Date Posted: May 02, 2006 at 7:02 AM
If it is an alarm that you are installing, this wire will provide +12V when the key is in any position other than off. This wire is what the system will use to allow you to put it into valet mode, and change programming options in most cases.
If you post the vehicle make/model/year and the system make/model someone may be able to give a little more assistance.
Date Posted: May 02, 2006 at 5:28 PM
According to the wiring diagram listed here the ignition wire is a BLACK / YELLOW in the ignition harness.
Posted By: xtremej
Date Posted: May 05, 2006 at 11:15 AM
From reading your posts I would have to strongly suggest you take your vehicle to a professional to have this alarm installed.
