2000 Durango lock prob
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=77215
Printed Date: May 10, 2026 at 7:56 AM
Topic: 2000 Durango lock prob
Posted By: Alpine Guy
Subject: 2000 Durango lock prob
Date Posted: May 03, 2006 at 11:46 AM
I have a 2000 dodge durango im working on right now, only problem is it wont lock the doors, I found the lt GREEN/ orange wire and the unlock works fine with the 1562 ohm resistor, however the 647 ohm resistor on the lock wire also unlocks the veh???? messed...i know... So does anyone have any other suggestions? If i send a straight (-) signal too the lt. GREEN/ orange it locks the doors but makes them try locking 3 times fast, obvioulsy a no no. The veh has keyless entry. Any suggestions? ------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Date Posted: May 03, 2006 at 11:57 AM
Would sending a (+) to the ORANGE / purple be ok? ------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Posted By: infinkc
Date Posted: May 03, 2006 at 2:15 PM
are the wires isolated by relays? they should be going into relays and output through the resistors. not sure on the ORANGE / purple. have your tried measuring the resistors to make sure its the right value also.
------------- There are 10 types of people in the world, ones that understand binary and ones that dont.
Date Posted: May 03, 2006 at 5:02 PM
ya, they were through relays, , i ended up using the ORANGE / purple as lock, and the proper wire as unlock so it disarms the alarm. The resistors were exact. ------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
