2002 MDX , 95 LS400, Alarm / RS
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=77244
Printed Date: May 10, 2026 at 12:57 AM
Topic: 2002 MDX , 95 LS400, Alarm / RS
Posted By: thesaint124
Subject: 2002 MDX , 95 LS400, Alarm / RS
Date Posted: May 03, 2006 at 7:17 PM
Hey guys, need a quick answer to this. looking to put a viper 791xv into this car, went to www.bulldog security to get the wiring diagram for the car, and they said a bypass module is needed. the 791 odly enough... https://www.bulldogsecurity.com/MTweb/products.asp?id=1007 and here is the installation manual for it as well. https://www.bulldogsecurity.com/pdf/Model791.pdf
Is this needed for the MDX, or is any bypass module needed for the car?
thanks guys...
Posted By: Twelvoltz
Date Posted: May 03, 2006 at 7:25 PM
Yes, you will need a bypass module, you can use the one listed which consumes a key, or one that is wired in to the vehicle and provides the correct data to the vehicle to allow it to start, like DEI's 555H.
Hope this helps
Date Posted: May 03, 2006 at 7:28 PM
great, thanks...
Date Posted: May 04, 2006 at 5:46 AM
also another quick question, also doing a basic RS on this guys 95 Lexus LS400 as well, I have the diagram for the car, but it only shows a factory disarm wire, no wore to re arm the factory system after RS is completed. I was thinking that if the factory alarm is armed with the drivers door lock, I could use the re-arm wire from the RS system to pulse the locks and re arm the system (with a relay) after RS?? is there an easier way?
anyone have a complete diagram?
thanks.
Posted By: thepencil
Date Posted: May 04, 2006 at 8:25 AM
DIRECTWIRE™ WIRING INFORMATION - LEXUS / LS 400 / 1995 / Remote Start
12volts blk/wht or wht/blue    +   ignition harness
Starter red    +   ignition harness
Second Starter
Ignition BLACK / YELLOW    +   ignition harness
Notes: When installing a remote start system you must interface with the tilt steering wheel, see directfax document #1068 for wiring information.
Second Ignition BLACK/ orange    +   ignition harness
Third Ignition
Accessory pink/blue    +   ignition harness
Second Accessory
Keysense
Power Lock GREEN/ red    -   at ECU in pass door
Power Unlock GREEN/ black    -   at ECU in pass door
Lock Motor
Unlock Motor
Parking Lights+ green or grn/orange      drivers kick panel
Parking Lights- GREEN / WHITE      low current, body ECU
Notes: Body ECU is located just in front of the parking brake pedal, bolted to the fire wall. Silver box with black plastic cover on the bottom. Must remove the cover to access plugs. One ten millimeter nut.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger RED / white    -   at body ECU
Dome Supervision
Trunk/Hatch Pin RED / blue    -   at light or body ECU
Hood Pin GREEN / WHITE    -   at body ECU
Trunk/Hatch Release blue (low current)    -   switch or body ECU
Power Sliding Door
Factory Alarm Arm GREEN/ YELLOW    -   in passenger door ECU
Factory Alarm Disarm green    -   in passenger door ECU
Disarm No Unlock
Tachometer BLACK / YELLOW    ac at ignitor
Notes: Ignitor located just in front of passenger shock tower.
Wait to start
Brake Wire GREEN / WHITE    +   driver kick panel
Parking Brake
Horn Trigger grn/red(low current)    -   at body ECU
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Date Posted: May 04, 2006 at 8:29 AM
I had all that except for the factory re arm wire... thanks.... would the senario in my above post work?
regards,
Date Posted: May 04, 2006 at 8:30 AM
nevermind.. it's still early here, do you have one of those diagrams for the 2002 MDX?
regards
Posted By: xtremej
Date Posted: May 04, 2006 at 8:37 AM
Try this link, you'll have all diagrams.
Date Posted: May 05, 2006 at 2:21 AM
Hey guys, will be installing 2 791xv's into a Lexus LS400, and a 2002 Acura MDX... Since I haven't had a chance to go over the cars yet, was wondering if anyone had information on the types of locks in these vehicles, as far as relays required, and if it's necessary to diode isolate as well...
regards
