1994 SC300 Scytek Alarm with remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=77498
Printed Date: May 07, 2026 at 11:28 PM
Topic: 1994 SC300 Scytek Alarm with remote start
Posted By: technol
Subject: 1994 SC300 Scytek Alarm with remote start
Date Posted: May 09, 2006 at 12:24 PM
Hi, I'm installing my first alarm/remote start in my 1994 sc300. I have the Scytek Galaxy 5000RS-2W and i'm a bit confused on how to hook up the alarm arm/ disarm and door lock wires.
In my situation the SC300 uses "Factory Alarm Arm common with lock " How do i wire this with my alarm having an arm and disarm? Do i wire these wires to the door lock wires?
Please help! thanks!
Posted By: xtremej
Date Posted: May 09, 2006 at 12:31 PM
You probably can, I'm not sure with scytek stuff but on some remote start alarms you can and have it trigger to unlock before remote start. Then re-lock after started to re-arm the fact. system. If it disarms with unlock wire and arms with lock wire. Whats make of your sc300, I'll see i my diagram lists a dedicated disarm wire?
Posted By: technol
Date Posted: May 09, 2006 at 12:45 PM
There is a dedicated disarm wire, on the 1994, but what i dont understand is there is no dedicated rearm wire, i guess that's what i'm confused on?
Posted By: xtremej
Date Posted: May 09, 2006 at 1:59 PM
If it arms with the lock wire, it will arm when you lock this is good. A dedicated dis arm wire means you just have to pulse this on remote start to disarm fact. alarm. You'll also have to pulse on unlock.
Posted By: xtremej
Date Posted: May 09, 2006 at 2:01 PM
Its fine that it has a disarm wire, when remote started this wire should get pulsed to disarm factory alarm and you won't have to trigger unlock wire then. It will arm factory alarm when you lock the doors, this is good. -------------
