06 Ranger door lock wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=78187
Printed Date: May 08, 2026 at 12:57 PM
Topic: 06 Ranger door lock wiring
Posted By: saleen49
Subject: 06 Ranger door lock wiring
Date Posted: May 23, 2006 at 12:54 PM
I just picked up an 06 Ford Ranger XLT and need to identify the two wires that activate the passenger door lock when pushing unlock on the key fob twice (to unlock both doors), I installed an electric tail gate lock and would like to be able to have the tail gate unlock only with the passenger door lock, also looking for 06 Ranger wire color chart, thank you for any help,
Posted By: spookiestylez
Date Posted: May 23, 2006 at 10:46 PM
| 12volts | yellow (x3)(common 40A) | + | ignition harness | | Starter | RED / lt. blue | + | ignition harness | | Second Starter | N/A | | | | Ignition | lt. GREEN/ purple | + | ignition harness | | Second Ignition | N/A | | | | Third Ignition | N/A | | | | Accessory | gray / YELLOW | + | ignition harness | | Second Accessory | BLACK/ lt. green | + | ignition harness | | Keysense | BLACK/ pink | - | ignition harness | | Power Lock | pink / YELLOW | - | SJB, large black plug, pin 5 | | Notes: The SJB (Smart Junction Box) is the fuse/relay box in the passenger kick panel. | | Power Unlock | pink/lt. green | - | SJB, large black plug, pin 9 | Notes: The SJB (Smart Junction Box) is the fuse/relay box in the passenger kick panel.
The SJB in this vehicle shuts down after the doors have been locked for a certain time period, to wake up the system refer to DirectFax document 1093. | | Lock Motor | red | 5wi | SJB, gray plug, pin 9 | | Notes: The SJB (Smart Junction Box) is the fuse/relay box in the passenger kick panel. | | Unlock Motor | lt. blue | 5wi | SJB, large black plug, pin 7 | | Notes: The SJB (Smart Junction Box) is the fuse/relay box in the passenger kick panel. | | Parking Lights+ | brown | + | SJB, brown plug, pin 8 | | Notes: The SJB (Smart Junction Box) is the fuse/relay box in the passenger kick panel. | | Parking Lights- | WHITE/ black | - | switch or SJB, sml blk plug, pin 16 | | Notes: The SJB (Smart Junction Box) is the fuse/relay box in the passenger kick panel. | | Hazards | same as turn signal wires | | | | Turn Signal(L) | lt grn/wht (F), lt grn/org (R) | + | turn signal switch | | Turn Signal(R) | wht/lt blu (F), org/lt blu (R) | + | turn signal switch | | Reverse Light | BLACK/ pink | + | driver kick, harness to rear | | Door Trigger | yellow/black (D), gray/red (P) | - | SJB | Notes: The driver door trigger is yellow/black in the large black plug, pin 6. The passenger door(s) trigger is gray/red in the small black plug, pin 3. Use both wires and diode isolate each from each other and the control module. Refer to DirectFax document 1076 for wiring information.
The SJB (Smart Junction Box) is the fuse/relay box in the passenger kick panel. | | Dome Supervision | BLACK/ lt. blue | + | SJB, gray plug, pin 14 | | Notes: The SJB (Smart Junction Box) is the fuse/relay box in the passenger kick panel. | | Trunk/Hatch Pin | N/A | | | | Hood Pin | N/A | | | | Trunk/Hatch Release | N/A | | | | Power Sliding Door | N/A | | | | Factory Alarm Arm | N/A | | | | Factory Alarm Disarm | N/A | | | | Disarm No Unlock | N/A | | | | Tachometer | tan / YELLOW | ac | PCM, pin 48 | Notes: The PCM (Powertrain Control Module) is on the passenger side firewall, under the hood.
For tach, can also go to the ignition coil pack or any fuel injector and use the wire that is NOT red. | | Wait to start | N/A | | | | Brake Wire | lt. green | + | brake pedal switch | | Parking Brake | RED / yellow | - | switch or SJB, lrg blk plug, pin 17 | | Notes: The SJB (Smart Junction Box) is the fuse/relay box in the passenger kick panel. | | Horn Trigger | yellow/lt. green to dk. blue | - | switch or SJB, sml blk plug, pin 18 | | Notes: The SJB (Smart Junction Box) is the fuse/relay box in the passenger kick panel. | | Memory Seat 1 | N/A | | | | Memory Seat 2 | N/A | | | | Memory Seat 3 | N/A | | |
| Interface Module: | Category: Immobilizer Bypass | Required: Yes | Type: SecuriLock | | Part #: 1100F | | Alternate Part1 #: 556SW | | Alternate Part2 #: 556UW | | Alternate Part3 #: DesignTech 20402 | | Alternate Part4 #: DesignTech 29402 | | Notes: Standard on all models. |
