Intellistart 4
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=78194
Printed Date: May 08, 2026 at 11:22 AM
Topic: Intellistart 4
Posted By: mrvf
Subject: Intellistart 4
Date Posted: May 23, 2006 at 3:02 PM
Hi,
I have 1999 Honda Civic SI (EK4) with Clifford Avantguard 5, when i remote start the engine my abs light comes on...then shuts of when i put the key in on position.
This is correct?
Sorry for my english.
Regards,
Marco
Posted By: Twelvoltz
Date Posted: May 29, 2006 at 7:08 PM
Did you install this yourself? If you paid someone to install it, then take it back to them, it needs to be fixed. It sounds as if someone missed a required wire. When you turn the key to the on position all ignition and accessory wires are energized, when installing a remote start it is not neccessary to energize every wire, but the wire that controls the ABS computer should definately be energized.
